2005 Acura RL Hands Free bluetooth pin code reset
Old Dec 11, 2014 | 09:31 PM
Yemeni_Alaskan's Avatar
I bought my car from a person who doesn't know what his past wife set as a 4 digit pin code for Handsfree link.
We tried many codes from factory to assumption with no luck. It keeps asking me for pin code and I don't know it. Is there anyway I can get through that so I can enjoy my callings???
Old Dec 20, 2014 | 04:08 PM
blaser's Avatar
unfortunately not, you need to replace the unit.
I had the same problem when I bought my car, it was under warranty so the dealer replaced the BT unit, he couldn't reset it.
Old Dec 20, 2014 | 09:04 PM
GASKICKER's Avatar
The only code Ive seen for the handsfree was when making the connection it asks for a 4 digit code that the handset then asks for. I bought my car used and didnt have any troubles setting it up. Thats weird that there would be a security code that the dealer couldnt reset or that couldnt be found another way like the NAV and radio have. AND a code that doesnt allow any connection unless given is even weirder, considering what it is accessing.
Old Dec 21, 2014 | 08:35 PM
oo7spy's Avatar
You should be able to reset all of the factory settings. I would think that should reset any custom codes.
Old Dec 22, 2014 | 04:50 PM
Karl_in_Chicago's Avatar
Agreed! Anyway, thumbing through the manual I do see a procedure for clearing/resetting the HFL. On page 243 "Clearing the system":
<Press and release Talk button>
After the beep say "System"; the HFL response should be "System options are Setup and Clear"
After the beep say "Clear"; HFL response should be ‘‘This process
will clear all paired phones, clear all entries in the phonebook, and
clear the passcode. Is this what you would like to do?’’
After the beep say "Yes"; HFL response should be ‘‘Preparing to
clear all paired phones, all phonebook entries, and the
passcode. This may take up to 2 minutes to complete.’’
After the beep say "OK"; after a short period of time the HFL response should be ‘‘System has been cleared. Returning to the main menu.’’
Hope this helps.
Old Dec 22, 2014 | 06:04 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
If Karl's method doensn't work (and I don't believe it will as it defeats the purpose of a PIN to begin with), your local dealer can clear the system.
Old Dec 22, 2014 | 10:12 PM
oo7spy's Avatar
I don't see how it defeats the system. A pin just makes it easy to know what code needs to be entered. It's not as though there is any security breach if someone can pair their phone with your car.
I think you have a lot more to be worried about if someone can reset the system than if they know your HFL pin.
Old Dec 23, 2014 | 08:03 AM
NBP04TL4ME's Avatar
We are likely talking about two different PINs. There is one that is used to pair and recognize your particular phone and there is one that can be enabled and requires you to enter it before accessing the HFL to make calls and your phone book.
Old Dec 23, 2014 | 07:35 PM
oo7spy's Avatar
Ah, I never used the phone book, so I don't know that area.
Old Jan 31, 2016 | 09:06 AM
Aina Ekundayo - Aina's Avatar
Hope this helps.
This your information is very good but, my problem is complex. I bought Acura MDX 2005 in Nigeria and I was trying to connect the pass code. The system keeps telling me to enter 4 digits pin which I dont have.
The system didn't allow to do anything to connect or reset the passcode.
Please what can I do ?
Old Feb 3, 2016 | 10:27 PM
oo7spy's Avatar
You have to find the 4 digits. Look in the manual, manual cover, glove box compartment or the under the hood fuse box lid. If all else fails, call Acura Care.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
MyKids&Cars
Oct 13, 2015 11:44 PM
nuldabz
Sep 3, 2015 05:49 PM
SUPRMN84
Sep 2, 2015 11:50 PM
