Replacement FOG Light Help?
Old Feb 16, 2014 | 09:38 PM
Mr.Tea's Avatar
Hello lads I wanted to upgrade my current fog light on the RL to Yellow or brighter white to match the Headlight. Can any one point me in the right direction for the Yellow Fogs? or replacements bulbs. I currently live in an area that has allot of fog at night and early morning when i commute so i was thinking the yellow might be better for this.Please correct me if i am wrong.
Thanks.
Old Feb 17, 2014 | 01:10 PM
oo7spy's Avatar
Simplest swap (plug and play) would be PIAA Yellow H11.
Amazon.com: PIAA 13511 H11 12-Volt Plasma Ion Crystal Yellow 55=100-Watt Bulb - Twin Pack: Automotive Amazon.com: PIAA 13511 H11 12-Volt Plasma Ion Crystal Yellow 55=100-Watt Bulb - Twin Pack: Automotive
Old Feb 17, 2014 | 01:42 PM
HEAVY_RL's Avatar
agreed
Old Feb 17, 2014 | 01:54 PM
Mr.Tea's Avatar
Would these be brighter than my current "FOGS" and will i have any electrical or heating issues "melting" the housing with this?
Thanks.
Originally Posted by oo7spy
Old Feb 17, 2014 | 02:17 PM
oo7spy's Avatar
They should be brighter as OEM bulbs are crap. I also would not expect melting issues, but since I have never owned them (just heard good things), I can't say with certainty. A few members have run them here and I couldn't find a reported issue.
Old Feb 18, 2014 | 07:31 AM
HEAVY_RL's Avatar
No melting issues here, I am getting ready to upgrade to yellow HIDs in the spring.
Old Feb 20, 2014 | 12:18 AM
Mr.Tea's Avatar
Are the yellow HIDS different from the PIAA bulbs mentioned above? Is there any examples of those?
Old Feb 20, 2014 | 08:11 AM
HEAVY_RL's Avatar
indeed, one is a bulb replacement and one is an HID bulb with a ballast.
Old Feb 20, 2014 | 11:14 AM
oo7spy's Avatar
HID's are considerably more expensive and more work. A quality setup will run you at least $150 and won't really provide any better light quality since the housing is designed for a halogen bulb. Throwing and HID in there with no projector retrofit will just scatter the light.
Stick to the halogen H11s.
Old Feb 20, 2014 | 03:17 PM
HEAVY_RL's Avatar
all valid points.
Old Mar 22, 2014 | 09:50 AM
Ballinger's Avatar
The halogen H-11's are a simple swap and the yellows will make you more visible to others in heavy fog. They don't really give you much better vision of the road, because our headlights are both "on" and much brighter.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
