Quick and easy way to run amp power wire through firewall
Like many of you out there I was very hesitant about drilling through the firewall and having to paint and seal it under such a confined space in order to run an amp power wire to my trunk. I searched quite a bit online to see if there was an alternative to drilling, perhaps an existing hole that was not utilized. I eventually ending up on cardomain.com and checked out other Acura RLs that have added an amp and sub to their system. I stumbled across "farabeast's Acura RL" page and low and behold there it was.
As described by farabeast, "Through this opening the wire doesn't go straight into the engine bay, but rather it goes into a frame rail and after a few inches exits to the right into the engine bay. The hole on the engine bay side is slightly smaller, so anything larger than 4g may not clear it with room for a rubber grommet. The wire in the photo is just the wire used to fish the 4g wire."
Hopefully that makes a lot of your installs just that much easier.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
