Is this a normal HFL problem with the iPhone?
I can get my iPhone to pair with the HFL just fine. I can place and answer calls from the steering wheel controls, and the battery and signal icons come up in the display.
However, if I dial a number from the iPhone itself, it won't work. The phone will dial, but the car won't recognize the call. If I hit the HFL button and say "transfer", it responds that "there are no active calls." If I keep "HandsFreeLink TM" selected as the audio output on the iPhone, I can't hear or talk to the person I am calling. I have to switch off of the bluetooth connection and talk into the phone.
Is this normal for other iPhone users, or is there something wrong with my system and/or the iPhone? If that is the case, any ideas on what might fix it? Thanks.
The only real fix is to voice dial the number yourself using the HFL button and the voice commands - which is a pain if you can't remember the number. What I usually do is bring up the contact list on the phone then voice dial from the car. An inelegant solution, but it works.
My iPhone 3G will transfer over to the HFL in my '06 if I dial from the handset, and then choose "handsfree link" from the source menu on the iPhone. I don't need to press any steering wheel buttons, or use the "transfer" command, but it won't transfer over UNTIL the call is connected. In order for there to be a call "in progress" there must be a connection - which means your party has to have answered. That basically means you will miss the first few seconds of the call, where people are saying "hello? hello?" and they can't hear you .
It's sub-optimal, but it does work for me.
This is a phone specific issue. Some phones fully linked, some partially. The bluetooth stacks on each phone are different. I have a 2 yr old treo (windows mobile) and the "transfer" command works fine. It will transfer when ringing before call is connected.
I just tried to pair a new 3G iPhone with my car (08 TL, navi). It paired fine, and I made one test call. But I could not end the call ... the 'end' button (steering wheel) was ignored. I ended up turning off the car. I then restarted the car; tried to initiate a call ('Call 511') but car said, 'no phone found' or similar. So I tried to pair again, but it said '6 phones already paired' (I've successfully paired 5 others, and the iPhone was the 6th). So I deleted the iPhone pair, and started again.
Second time around, it would get stuck right after "Phone Setup" and "Pair". I again had to turn off the car completely. I tried about 5 times, and gave up. Once I gave up, I powered back up my trusty Motorola Q, which worked flawlessly. I've also had no problems (pairing/etc wise) with a samsung blackjack, palm treo 700w, and a few others. This is a real bummer because I was all set to buy the iPhone but successful pairing and operation with my 08 TL is essential ... I use it all the time!
Are there updates to the phone that will fix this? If updates to the car are required, will they do that for free under warranty?
Thanks!
Thanks!
Thanks!
Thanks!
mada51589
05-03-2022 08:54 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
IndycarFaster
09-11-2015 02:52 PM
