Navigation update.
Old Dec 27, 2012 | 01:01 PM
projekt_shocker's Avatar
Navigation update.
Currently running a 4.12 white disc in the car. I just got the 4.92 white disc for the car.
I know that I will need to update the firmware of the navigation after doing some research on the forums. Tried to acquire the 1.29 update disc and have no luck in getting it. I know that a forum member have a dropbox link to the update disc, but would like to update my maps before new years.
Is there anyone here on the forum that have the firmware update disc? I am willing to buy the update disc and will send payment via paypal.
Let me know!
Old Dec 27, 2012 | 02:02 PM
HEAVY_RL's Avatar
Ivan was no help?
Old Dec 27, 2012 | 02:25 PM
Originally Posted by HEAVY_RL
Ivan was no help?
Haven't emailed me the link yet... been a week now.
Old Dec 27, 2012 | 04:55 PM
mitchkramez's Avatar
Ivan, your dealer can do it for free in most cases, or at most $30.
Old Dec 28, 2012 | 02:18 PM
Nearest Acura dealership for me is about an hour. I was hoping to get a dropbox link from Ivan since he have it up there in the clouds. I might have to make an appointment to acura.
Old Jan 4, 2013 | 09:14 AM
Finally got the update from Ivan. Everything worked fine up until my burned DVD copy of the 4.92 maps started to get DVD read error messages.
I burned the copy with the slowest speed possible (2.4x) and still no good.
Light at the end of tunnel is diminishing again.
Old Jan 5, 2013 | 04:04 PM
blaser's Avatar
There some kind of copy protection on the DVD and you can't make a copy, you need to use the original.
Old Jan 6, 2013 | 09:31 PM
Well I got a copy of the 4.A2 version (2012) that I just made and it worked!
Just had to insert two bin files and burn it into a image and the navigation system updated it self and worked like a charm. After a couple days of research I now have a updated navigation working for my car.
PM me for more info.
Old Jan 16, 2013 | 11:40 PM
Black63's Avatar
6th Gear
Glad you got yours working! I just got my 05 a few days ago and am looking to update the Navi as well. Since I'm new I can't send PMs yet - wondering if you could PM me the link to the dropbox update file. Thanks!
Old Jan 17, 2013 | 06:06 PM
PM Sent
Old Jan 17, 2013 | 09:43 PM
Black63's Avatar
6th Gear
Originally Posted by projekt_shocker
PM Sent
Thanks!!
Old Jan 18, 2013 | 10:37 AM
Originally Posted by Black63
Thanks!!
NP, let me know if you run across any issues.
Old Jan 21, 2013 | 08:58 AM
Tyzing's Avatar
I'm really confused, from the way the forum is structured it appears that the new Navi or 2nd Gen starts in 2005 but isnt it 2006?
I have a 2005 RL older body type which I would think means I dont have the same Navi as the 2006+ am I wrong?
I also cant seem to find the history of disc's to know what I can upgrade to and what I cant. I think I'm on 4.69 or something like that...if that doesnt sound right I'll check again.
Old Jan 21, 2013 | 09:18 AM
HEAVY_RL's Avatar
are you trying to convince us that our '05's are really '06's?
Dont spread your confusion, that shit is contagious.
If your car is the old body style you have an 04 or older...
Old Jan 21, 2013 | 09:57 AM
Tyzing's Avatar
You understand why I'm so confused...
Old Jan 21, 2013 | 09:59 AM
Tyzing's Avatar
I know mine is a 2nd Gen...year before was the true old body style...but wasnt it updated again to 3rd gen well before 2012 like the forum suggests?
Either way, that doesnt really matter...I just need to know what discs I can use.
Old Jan 21, 2013 | 01:47 PM
oo7spy's Avatar
What the hell...
Look at your VIN (since you conveniently blurred it even though it has no personal information). Does it say "KB1" or "KA9" anywhere in it? KB1 is the chassis code for the 2G RL which started production in 2004 and went on sale later that year as a 2005 model. The Nav system from 2005-2012 is unchanged. KB2 is the chassis code for the 2009-2012 RL, but it was only a mid-model change (MMC) and did not contistute a new generation.
Old Jan 21, 2013 | 02:42 PM
Tyzing's Avatar
Originally Posted by oo7spy
What the hell...
Thanks for the response and sorry for the confusion...am I being dense here? Quite possible, but hopefully I'm not the only one that got confused by this
Anyways I looked at my VIN and it had KB1 in it...
Old Jan 21, 2013 | 03:11 PM
oo7spy's Avatar
No worries. Your density likely depends on what you ate/drank for lunch.
I assume all of your confusion came from the change to the RL in 2006 when the Tech model was introduced and the base model received a "compass" instead of standard navigation. This was a cost reduction move and allowed sales access to HI and AK which are out of the range of the satellites.
Old Jan 21, 2013 | 03:22 PM
Tyzing's Avatar
Makes sense now and you are correct on where my confusion came from!
So, with all that said...which discs am I able to use? The most recent "2013 White DVD Map Update for 2005 RL and MDX v4.B1 MapCare" should work fine? (as long as I've upgraded to that .63 or whatever that one is you have to use first from Ivan)
Just want to make sure I'm on the right track.
Old Jan 21, 2013 | 03:33 PM
oo7spy's Avatar
There was only ever one firmware update, 1.29.00 that happened with the 4.31C disc. If you can run a version later than 4.31C, you are already updated and can run whatever you please. (Not sure about reverse compatibility, though.)
Old Jan 30, 2013 | 11:16 AM
MrJohns's Avatar
Hi all. Just bought an 05 RL and new to the thread. Wondering if upgrading to the new NAV is worth the cost?
Old Jan 30, 2013 | 11:36 AM
Professor's Avatar
Карты убийцы
If you are still running the original disks then yes. Otherwise I'd wait at least 3 years between updates... not much changes from year-to-year concerning maps.
Old Jan 30, 2013 | 01:35 PM
MrJohns's Avatar
Thanks Prof it's still the original disk.
Old Jan 30, 2013 | 06:53 PM
projektvertx's Avatar
May or may not be worth it. I updated from an '06 to '12 disc. Don't expect a huge change. What I noticed was updated POI's (which is what I expected it to cover anyways). I didn't notice much else. I think it really depends on how often you like to call up the POI's like restaurants and such.
Old Feb 24, 2013 | 07:47 PM
Mighty T's Avatar
6th Gear
Is Ivan still around? I need an assist....and does anyone know why Acuralink doesn't work? I just got the car about 2 weeks ago and I can't activate it. Thanks in advance.
Old Feb 24, 2013 | 10:15 PM
oo7spy's Avatar
Old Feb 25, 2013 | 09:06 PM
Mighty T's Avatar
6th Gear
projekt_shocker, can you help?
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
