Music Link
Old Apr 7, 2008 | 06:45 AM
miner's Avatar
Music Link
Well, this weekend my Music Link stop working. I can't even get the head unit to cyle through to CDC when I push the DISC button. I suppose it could hav come undoen from behind the player but I don't know how. I guess I'll call my dealer to see what my options will be since the Music Link has been discontinued. Anyone else experirnece this problem? What other options do I have (vendors) if I want to keep my XM active?
Old Apr 7, 2008 | 09:25 AM
ssim3's Avatar
05 slate grey e500 AMG sp
Try pulling the fuse on your stereo & reentering your codes. It is in the driver's footwell. My Dice unit needs to be reset like that once a month.
Old Apr 7, 2008 | 11:32 AM
miner's Avatar
The rest of the HU functions work - just not the CDC/Music Link. Would resetting be required if only the CDC does not work? If I do reset then codes for radio & Nav need to be entered?
Old Apr 7, 2008 | 12:25 PM
ssim3's Avatar
The radio & 6 disc on mine work fine, just not the ipod adaptor & xm wont work, but pulling the fuse resets everything. It will propmt you to put the nav code in with the wheel & radio code is put in with preset buttons.
Old Apr 7, 2008 | 01:01 PM
miner's Avatar
Please explain inputing code with 'wheel'. Thanks.
Old Apr 7, 2008 | 02:52 PM
ssim3's Avatar
there will be a number wheel on the nav screen & you use the big nob to select the numbers.
Old Apr 7, 2008 | 06:09 PM
miner's Avatar
Thank you.
Old Apr 8, 2008 | 12:43 PM
miner's Avatar
Even if the cable was bad shouldn't I be bale to toggle to the CDC via the disc button? Currently when I push the DISC button I only get CD choice, no CDC.
Old Apr 11, 2008 | 10:11 AM
miner's Avatar
Will be taking to dealer this afternoon for diagnosis.
Old Apr 11, 2008 | 11:55 AM
neuronbob's Avatar
Keep us posted!
Old Apr 11, 2008 | 06:28 PM
miner's Avatar
I lucked out - the dealer had another cable in stock and switched it out - all is good now. Hopefully the next time it goes bad the iLink will be available as a replacement. With my 120000 mile warranty I should be golden.
rcs86
Aug 2, 2016 06:52 PM
eastcoastguy
Oct 29, 2015 03:00 PM
lanechanger
Oct 13, 2015 10:56 AM
thegipper
Sep 28, 2015 01:01 PM
Brandle34
Sep 23, 2015 07:20 PM
