How to Pair Bluetooth w/ 07 RL: "Phone Setup" Not Available
Old Jan 25, 2007 | 05:21 PM
Big Bad Wolf's Avatar
I want to pair my Bluetooth phone with my '07 RL. The owner's manual and handsfreelink.com both state "Press and release the Talk button on the steering wheel and wait for the "beep" before you speak. Say "phone setup". I do this and the car responds with "Setup what?" Entering a voice command of "phone" at this point gets no response. The nav screen displays a variety of setup options to choose from, but phone setup is not one of them. I've tried this with the ignition switch in every functional position and get the same result. I can't find any additional references to phone pairing that explain why phone setup isn't available as documented. Can someone tell me what's happening here and/or how I can otherwise move forward with the pairing process?
Old Jan 25, 2007 | 05:31 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
Say "system" first (I think that's it), and then say "phone setup".
Old Jan 25, 2007 | 05:40 PM
backfire's Avatar
I will try to help you. You have to go into you phone. I have verizon and went to tools and then into connections. In connections I went to bluetoothand then setup. Then while in the car with ignition on you try to setup phone and car together. The car and phone must reconize each other. Only then can you set it up. I am not sure where you are with this. Hope this helps you
Old Jan 26, 2007 | 02:06 PM
Problem Solved
Thanks for the suggestions. This problem turned out to be due to an RTFM failure on my part, and to incorrect and misleading information in the owner's manual. After a closer reading of the Hands Free Link (HFL) section of the manual, I realized that the "Talk" button specified in the pairing instructions is the HFL Talk button; not the voice command button referenced throughout the rest of the manual. This distinction is not clear in the manual but can be deduced with thorough review of the HFL section. Hence, RTFM -- my mistake. After this ah ha I discovered that the "Phone Setup" command specified in the manual should actually be spoken as "Setup Phone". From here the instructions were reliable and I was able to pair my phones in quick order.
Old Nov 13, 2017 | 09:53 AM
accord_3000's Avatar
8th Gear
Has anyone been able to pair a new phone with an older car? I have a Samsung S8 and just bought a 2006 RL, the car, nor the phone see each other.... If this is in the wrong place let me know thanks!
Old Nov 13, 2017 | 04:59 PM
truonghthe's Avatar
I got Iphone 8 plus working with my 06 RL.
Old Nov 13, 2017 | 05:32 PM
projektvertx's Avatar
I've noticed the behavior can sometimes be erratic with Androids. It occasionally takes several minutes before the phone is able to pair. I've noted iPhones generally take less time and are quicker to pair with the RL.
mlody
Dec 4, 2019 02:11 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SUPRMN84
Oct 7, 2015 09:46 PM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
ivan06106
Sep 26, 2015 04:38 PM
