HFL talk button
Old Dec 12, 2010 | 11:11 AM
blitz960's Avatar
HFL talk button
Guys,
Finally got my 06 RL yesterday replacing my 3rd gen TL. Awesome car.
Need help. Why is it when I push teh HFL Talk button to pair my phone, I dont hear the beep or even anything at all? My TL beeps and waits for a voice command whenever I press the HFL Talk button. Worries me now that I can't even pair my phone or maybe even the Talk button is dead.
Also, the rear headrestraint button on the roof, when I pressed it, nothing happens. Did it go bad too?
Finally, they only gave me a key fob. Is it really expensive to buy a 2nd one? I heard it might be extremely expensive. Please help as I'm itching to get the bluetooth set. Thanks!!!
Old Dec 12, 2010 | 11:46 AM
HEAVY_RL's Avatar
Being a member since 07 I dont have to tell you that there is a lot of info to be searched.
Here is a thread that may help:
https://acurazine.com/forums/showthr...luetooth+phone
The button only drops the headrests you have to raise them manually
And a new key fob can be 500 bucks from the dealer, you should contact some of the board sponsors.
Old Dec 12, 2010 | 12:01 PM
blitz960's Avatar
I've actually done a search but all i found previously was problems pairing or finding the phone. Mine is actually not finding the phone but the seems like the HFL button is dead. No beep at all after I press it. But I'll search again and see maybe I might have missed it in my previous search.
Old Dec 12, 2010 | 01:20 PM
HEAVY_RL's Avatar
This may be a dumb question, but is the volume up on the radio?
Old Dec 12, 2010 | 06:09 PM
blitz960's Avatar
volume is normal. I guess normal in a sense that I was listening to CD before I got home and started to mess with the Bluetooth.
Now, the Homelink doesnt work. It worked on my previous 3rd Gen TL. My garage is the rolling code version and I did it the same way with the TL. Man, starting to regret selling the TL and getting the RL...
Old Dec 12, 2010 | 06:54 PM
HEAVY_RL's Avatar
Well from what I've noticed the HFL and the Radio have separate volumes. When you hit the button (not the round one, the one you use to answer a call) does the MID change?
Its known that programing those rolling codes takes some patience to get it right
Old Dec 12, 2010 | 09:51 PM
scottycruz's Avatar
I believe there is seperate volumes for HFL and radio. I had trouble with the homelink then finally figured out I had to press a Learn button.
Old Dec 13, 2010 | 06:07 PM
blitz960's Avatar
Got the Homelink done finally but the HFL is still no good. I tried to turn the volume knob after I press the HFL Talk button but nothing. I doubt it but is there a separate volume knob for the Bluetooth?
Also, when I pressed the HFL button, nothing changes in the MID...man, i hope it is not the Bluetooth module that went out...
Old Dec 13, 2010 | 06:36 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
It may be possible your HFL module is inoperative.
Does your phone allow you to 'see' other Bluetooth devices? Most smartphones have this feature. If your HFL is active you will see the HFL in the device list. If not, likely your HFL module is disconnected somehow or not working,,,and needs dealer intervention.
If you do not have a phone that does this, try a BT laptop or borrow a smartphone.
Old Dec 13, 2010 | 06:44 PM
HEAVY_RL's Avatar
damn, tampa might be right... sorry.
A shot in the dark might be pulling the battery cables, but I doubt that will work.
Old Dec 13, 2010 | 06:49 PM
getakey's Avatar
If you have the audio displayed in the Nav screen, it will change to an HFL diagram when you press the HFL button.
Also, not trying to be insulting, there are 2 different voice buttons. One for HFL and one for voice commands.
Old Dec 13, 2010 | 07:11 PM
blitz960's Avatar
Yup, I think my HFL is fried. When I switch it to audio in the nav screen and pressed the HFL Talk button, the screen didnt change to the HFL screen like my TL did. Also, my blackberry did not "find other device" during a search.
So, looks like I'm screwed with a bad module.
Now, the front passsenger wheel is making noise when I go through a series of bumps. Sounds like a pool ball being shaked in a shoe box. Maybe bushings?
Old Dec 13, 2010 | 07:42 PM
getakey's Avatar
bummer
Don't suppose it could be as simple as a fuse?
Old Dec 13, 2010 | 08:13 PM
blitz960's Avatar
hmm.. definitely worth a check tomorrow after work. Fuse box under the hood, I assume?.. Wow, never thought of that.. crossing my fingers..I guess none of you guys ever had this problem, huh?
Old Dec 18, 2010 | 04:03 PM
blitz960's Avatar
well, tried to find the fuse related to Bluetooth but could not find it. Open the fuse box under the hood and looked at the back of the fuse box cover. Nothing there indicates a fuse that is related to Bluetooth, not even steering wheel control. Anyone know where to find that fuse?
Old Jul 5, 2014 | 08:13 AM
ManMan88's Avatar
I am having the same issue. My HFL is not working at all
Old Aug 26, 2014 | 12:13 AM
Terrell Johnson's Avatar
Hfl
My HFL is reponsive but cannot find my phone nor anyother phone for that matter i think i need to replace my bluetooth reciever thingy but i dont know where to find it in the car
Old Aug 26, 2014 | 01:18 AM
Mike734's Avatar
I had similar problems with the bluetooth phone system. Check out this thread: https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/can-not-pair-iphone-replace-hfl-module-867170/
You can find the modules cheap and do it yourself. Good luck.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
