having to manually connect to HANDSFREELINK
Old Feb 11, 2013 | 02:47 PM
scrim67's Avatar
...I just bought a new phone....MOTOROLA RAZR HD MAXX
my former phone integrated to my RL HANDSFREE Link just fine.
The phone is pairing but the problem seems to be when I make a call from the handset while connecting the icon changes from "bluetooth" to "handset" so then I have to manually press that button again to get the dropdown box and choose "bluetooth" to transfer the call back thru HANDSLink.
when I paired my MOTOROLA bluetooth earpiece headset my phone didn't do this and stayed on bluetooth
any ideas?
scrim
Old Feb 11, 2013 | 03:47 PM
getakey's Avatar
Not quite sure of exactly the symptoms you are describing. However, if you initiate the call from the handset rather than handsfree, you have to voice the command, "Transfer" to get back to handsfree link.
Old Feb 11, 2013 | 04:00 PM
scrim67's Avatar
I really could have sworn with my older phone as long as the phone was "connected" to the bluetooth even if I initiated a call from handset it stayed on the handsfree unless I changed it.....I could be wrong...
because my '07 RL doesn't integrate the phonebook I usually start my calls via the handset
scrim
Old Feb 11, 2013 | 04:58 PM
scrim67's Avatar
ya know u are probably right....I do recall at times with my old phone having to hit the bluetooth tab........I guess since most of my calls are received and/or in the internal HANDSfreelink phonebook I didn't notice it too much
scrim
Old Feb 12, 2013 | 09:00 AM
scrim67's Avatar
another issue
ok,
I'm starting to think there is an issue as driving to work I finally got my first incoming call in the car with my new phone...
unlike my old phone the handsfree link after hearing the verbal prompt "you have an incoming call" automatically picked up the call without giving me any option not to pick it up. This is not good for me as sometimes I don't want to pickup that call necessarily.
I looked on my phone for any "auto-answer" feature but don't see anything.
any ideas as this could get annoying.
mike
Old Feb 12, 2013 | 09:13 AM
scrim67's Avatar
ok..I just found a setting called "auto answser on headset" that had "after 2 seconds" checkmarked.....i've changed that to "none" so that should clear up the issue i'm thinking.
scrim
Old Feb 12, 2013 | 09:48 AM
HEAVY_RL's Avatar
if we sit quietly I think you may solve all your problems.
Old Feb 12, 2013 | 02:14 PM
scrim67's Avatar
I know i'm beating a dead horse here but i still think there's a bug somewhere....
i'm sitting here in my office with a bluetooth headset on and even when beginning a call via the handset it "knows" i'm on the bluetooth and the call connects via bluetooth...
conversely, if i'm connected to HANDSFREE LINK in my vehicle and I begin a call via the handset it says "bluetooth" for a moment on the handset before changing to "handset" and then I have to manually hit a dropdown box and hit "bluetooth" to hear the call over the bluetooth in my RL.
scrim
Old Feb 12, 2013 | 02:19 PM
getakey's Avatar
Yes, I think you are beating a dead horsse. IMO, the behavior is by design. If you initiate call from handset, it assumes you want that call private. Yet, there is a quick voice command (i.e., transfer) to transfer to HFL without "manually" doing anything on the handset.
Old Feb 12, 2013 | 02:49 PM
HEAVY_RL's Avatar
Old Feb 12, 2013 | 03:19 PM
oo7spy's Avatar
It really is a waste of time trying to debug compatability issues between technology from 2004 and 2013 if you already have a work around.
Old Feb 12, 2013 | 03:25 PM
getakey's Avatar
why do you think this is a compatibility issue?
Its always worked this way.
The difference between HFL and a bluetooth ear piece is the ear piece is private. Thus, initiating call from hand set with ear piece engaged would obviously go to ear piece.
I think Acura got this one right
Old Feb 12, 2013 | 03:32 PM
oo7spy's Avatar
OP claims his other phone did not do this . I chalk it up to Acura having to design a system that will work with technology that can hardly be predicted, but I do think your idea makes sense.
Old Feb 12, 2013 | 03:33 PM
getakey's Avatar
with all do respect to OP, I doubt that was the case
Old Feb 12, 2013 | 03:39 PM
oo7spy's Avatar
Originally Posted by scrim67
I really could have sworn ...
I went back and read this. Doesn't really exude confidence.
Old Feb 12, 2013 | 03:44 PM
getakey's Avatar
Although I've had similar moments
Old Feb 13, 2013 | 08:11 PM
scrim67's Avatar
i was in my buddy's RDX yesterday and confirmed that his HANDSFREE is working the same way mine is so this issue can be put to bed zzzzzzzzzzzzz
Old Feb 13, 2013 | 08:38 PM
HEAVY_RL's Avatar
nighty nite.
Old Apr 17, 2013 | 11:04 AM
jmoser1134's Avatar
Dont listen to the less than courteous responses. One of these users normally responds this way. He even copies intricate RL repair instructions from other users on another forum as his own.
Your issue is with your android operating system. With the recent Jellybean update my phone/HFL connection has the exact same issue. Worked before the latest update when dialing from phone and BT on. Automatically switched to HFL and talked through car's system. When I got the recent upgrade, which RAZR HD Maxx has, the issue you describe started for me. Never prior and I owned the car from new (06). Many phones, android and not in the beginning and this is the first time this has come up. It started the day I got the most recent upgrade to Jellybean.
Find a friend with android Ice Cream Sandwich system (or below) and pair the phone. HFL will work with a call initiated by phone dialing if BT is on and phone is paired.
I have found no solution others that the reconnection of BT on the phone after I initiate the call. Not desirable at all for me, but it is what it is.
Old Apr 17, 2013 | 01:42 PM
oo7spy's Avatar
Old Apr 17, 2013 | 02:37 PM
getakey's Avatar
Interesting, now my Android is working just the opposite after a recent update.
Before, if I initiated call from phone, I had to use transfer command to move it to HFL.
Now, initiating call from phone automatically engages HFL. This is the 4th phone I've had and every phone worked the same way including this one up until the update, that is requiring Transfer command.
Old Apr 17, 2013 | 04:59 PM
HEAVY_RL's Avatar
I think he is talking about your mom.
None the less you have to love a 50 year old troll with 3 posts in 8 years who bumps old threads to talk shit.
Bravo.
Old Apr 22, 2013 | 11:21 AM
scrim67's Avatar
thank you for what I truly believe is the most accurate answer on this thread
hopefully the next ANDROID update will fix this bug
mike
Biggie_B
May 27, 2025 05:51 PM
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
dirleton
Sep 25, 2015 12:25 AM
