grom hon1a3
Old Nov 13, 2014 | 09:43 PM
dre707's Avatar
grom hon1a3
I'm about to purchase the from Hon1a3 but wanted to ask a few questions do you plug this into the back of receiver or in the trunk where the xm radio is? And is this product any good or do you recomed the usaspec?
Old Nov 13, 2014 | 11:39 PM
dre707's Avatar
I was looking at one from autotoys.com and the instructional video showed it being installed in the trunk where the xm box is I need one like that so I can install it easily without having to remove radio so if you guys know what brands go installed in the trunk?
Old Nov 13, 2014 | 11:40 PM
dre707's Avatar
Here's video
ACURA RL IPOD & BLUETOOTH STREAMING, XM NAV TRAFF…: http://youtu.be/TfFDm_gm7HA
Old Nov 14, 2014 | 09:05 AM
ChocBoyWonder's Avatar
For us Cannuck's we have to install behind the radio meaning it has to be pulled out. I believe you you are equipped with XM you need to install in the trunk. What exactly are you trying to accomplish?
Old Nov 14, 2014 | 12:33 PM
dre707's Avatar
I wanna connect an auxiliary to my rl so I can listen to music from my phone I know the USA spec you can install it in trunk but it's really expensive just wanna know if there's another brand that allows install in trunk instead of having to remove stereo
Old Nov 17, 2014 | 07:16 AM
HEAVY_RL's Avatar
Whats the budget here?
The usa spec isn't that expensive.
Old Nov 17, 2014 | 08:24 AM
oo7spy's Avatar
I'm guessing around a 1/4 bag.
Old Jan 15, 2015 | 09:19 AM
nore03's Avatar
Randy is the Future
Purchased this unit over the weekend, after connecting it, it wouldn't work over the XM unit so I disconnected the XM unit then it worked fine, but the volume was limited. Not that I need to listen to my music on max but I would like the option of having it higher than what it allows for. After I put everything back together, it no longer works and now I can not open my audio menu, enter my address book, choose go home or have the nav unit speak during route guidance. I'm wondering if I have to have the XM unit connected to the system to get all those options. The issue I was having with the XM unit connected was that it would continue to play the xm music but wouldn't play anything I have the AUX connected to.
Old Jan 20, 2015 | 06:42 PM
nore03's Avatar
Randy is the Future
So to update, after I did some fishing around and unhooking and reconnecting I figured out how to get this unit working while still having the use of my xm radio. Basically once it is connected you get a 4th mode that you can only access while hitting the mode button on the steering wheel which is CD-C. It is just an extension that the grom unit made there. So now it works just normal like the AUX is built into the car. I drilled a hole through my "No an ashtray" section and just run the cord through there. I only kept coins in there before but it seems to be a fine place to keep it.
I Wanna Go Fast
19
Nov 6, 2016 07:04 PM
JDMCRX
Dec 3, 2015 09:54 PM
Vtecmane954
Aug 4, 2015 07:32 PM
acuratelyquick
Jun 18, 2015 01:05 PM
losiglow
Feb 25, 2013 07:11 PM
