Fog Lights and High Beams
Fk no!TheyldstroyEvrthing
Has anyone swapped the OEM on these?
The fogg lights are usually better it seems it cold weather coz yellow goes thru fog better than white or blue, but the high beams? They are halogen, and the philips ones claiming to be white, are not, they are quite yellow.
Did anyone manage a good halogen alternative that is really white?
Anyone tried LED? Mechanic says they burnout fast.
TIA
TIA
TIA
TIA
The "fog lights" are useless in fog, IMO. They are aimed low and to the sides. I just use them as auxiliary lights.
I think they are there to show the side of the road, like the divider, or the yellow line. The fog lights on your car they don't point to the side? Why you find them useless?
2007 LSM KB1 Tech w/CMBS
At one point a couple of years ago, VLEDs made a LED HB3 lamp that would work as a DRL. There was another made by Cree but those are not available any more. VLEDs was supposedly coming back out with an HB3 for the KB1 / 2 but I don't know if they ever did. There's a whole thread on this subject in General Discussion somewhere.
RL09 (01-03-2019)
RL09 (01-03-2019)
@jbird2212 Thanks! I may get these for the Fogs.
Do the 9005 work as DRL? it's the law here, and they seem not to from the questions to seller.
Remember btw our ballasts are 35W. On these it is mentioned in the title they are 60W, and in the details 76 watts.
The price is surely attractive, as Morimoto is 120$ but they are 23W, and work as DRL. The color on your picture is excellent. My philips halogen are yellowish.
RL09 (01-04-2019)
PIIYB or i'll PIIYB
I've only had my LED's in for a week so I can't comment on longevity, but the BEAMTech LED's I got from Amazon worked well for fogs and DRL/Hi beam. Only issue is that without a resistor, the 9005 LED's I bought give the dash error for DRL fault, but they're still fully functional.
Attachment 98516
Attachment 98517
Attachment 98516
Attachment 98517
RL09 (01-07-2019)
Seems JBird above got no faults on dash with his.
Hey it still beats TRS at 120usd+ for those. But the TRS has a 20 bucks unit to avoid flicker on LED DRL, they post it as an add on option when you choose the high beams in LED option for your vehicle (there's only one LED option). It may do the trick for your dash light if you install it. You can try that
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
RL09 (01-08-2019)
GroundedCustom
01-18-2016 08:08 AM
No1nfoProvided
04-25-2011 10:29 PM
Koreets.RU
07-19-2010 03:35 PM
gilla_monster
06-16-2010 10:07 PM
