low beams do not work. high beams do.
Old Feb 1, 2018 | 04:58 PM
missiehb's Avatar
4th Gear
2006 acura rl. both hi beams work. both low beams do not. checkd bulbs. checkd fuses. checkd steering comumn switch. is it ballast if hi beams still work? or ignitor? they sometimes flicker barely at first but it is rare. any suggestions
Old Feb 1, 2018 | 06:10 PM
projektvertx's Avatar
I would check to see if the ballast is getting 12 volts with the switch being on. That's a good starting point. Normally I'd say swap components from side to side but that's not gonna work here...
Old Feb 1, 2018 | 08:06 PM
missiehb's Avatar
4th Gear
Thank you
Question... is the ballast and ignitor for both bright and dims?? one connection? i will test out voltage this weekend. Thanks much.
Old Feb 1, 2018 | 09:08 PM
The 9006 brights are a separate harness then the D2S low beam harness. Hope that helps!
It's not like some German cars where one connection feeds the whole headlight
Old Feb 1, 2018 | 10:13 PM
missiehb's Avatar
4th Gear
thank you!!!!
Thank you!!!!
03tlswfl
Feb 12, 2019 06:09 AM
Edgar Oh
Mar 11, 2016 12:43 PM
GroundedCustom
Jan 18, 2016 08:08 AM
inkonspikuos
Feb 1, 2008 03:41 PM
gainful
Mar 14, 2005 06:14 PM
