Doors unlocking
Old Oct 28, 2008 | 12:05 PM
golfpro22's Avatar
9th Gear
Doors unlocking
I have the presets to lock the doors after 10 seconds of staring the car. Let's say for example that I am in my driveway and start the car, realize that I left something in the house, exit the car and shut the door. The door will obviously lock after 10 seconds. Will I be able to unlock the doors upon return?
Old Oct 28, 2008 | 01:08 PM
getakey's Avatar
I might be wrong, but I thought the doors only lock once the car has reached a certain minimum speed. In any case, you still would have the FOB and could open the door.
Old Oct 28, 2008 | 01:13 PM
Blazing GT's Avatar
I believe the door wouldn't lock.
Old Oct 28, 2008 | 01:28 PM
Ballinger's Avatar
Keep that key fob in your pocket!
Old Oct 28, 2008 | 02:20 PM
getakey's Avatar
yes - now that I think about it, once you open the door and leave with the FOB, it "knows" you are out of the car and beeps a warning
will not lock
Old Oct 28, 2008 | 05:07 PM
Treblig's Avatar
I think you're right, the doors lock after a minimum speed has been reached.
Old Oct 28, 2008 | 05:53 PM
rlerman's Avatar
try putting the key in your trunk and shutting the trunk, same thing happens when the key is in the cabin. Even if the key is in the cabin and the doors were to lock, you just touch the handle and it will open.
Old Oct 28, 2008 | 06:30 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
The doors will not lock when in PARK and the fob is inside the passenger compartment. (unless someone still in the car manually locks the doors).
There is no 10 second delay for auto door lock.
Selectable in the MID will be either when 10mph is reached, shifting out of PARK or no auto door lock (OFF).
From the 2006 RL Manual:
There are three settings you can
choose from:
SHIFT FROM P
The doors lock whenever you move
the shift lever out of Park.
WITH VEH SPD
The doors lock when the vehicle
speed reaches about 10 mph (about
15 km/h).
OFF
The auto door lock is deactivated all
the time.
Old Nov 1, 2008 | 12:19 AM
gcook's Avatar
on my cars, 05 tl and 07 rl, I can choose a few different options in the setup. To lock when you go in reverse, lock when you are going like 10mph and lock after putting car in drive.
I don't think there is an option to lock after x seconds .. without being in drive or reverse, which assumes someone is behind the wheel..
Old Nov 19, 2008 | 11:45 AM
azcohen's Avatar
How do you get the lights to flash to confirm you have locked your door when you get out?
Old Nov 19, 2008 | 11:54 AM
Post
It is in the MID Cutomize Settings...
When KEYLESS ACCESS LIGHT
FLASH is set to ON, some exterior
lights blink twice when you unlock
the doors by grabbing the driver’s
door handle while carrying the
remote.
While the multi-information display
is in the KEYLESS ACCESS SETUP
screen of the CUSTOMIZE GROUP,
press the SEL/RESET button. The
screen changes to CUSTOMIZE
MENU. Press the INFO ( / )
button until you see the above
display.
The same exterior lights blink once
when you lock the doors by touching
the door lock sensor while carrying
the remote.
Press the SEL/RESET button. The
screen changes as shown above.
Select ON or OFF by pressing the
INFO ( / ) button, then press the
SEL/RESET button to enter your
selection.
Multi-Information Display
Keyless Access Light Flash
Page 108 of the Manual
https://techinfo.honda.com/rjanisis/...6/JA0606OM.pdf
Old Nov 19, 2008 | 02:37 PM
azcohen's Avatar
Thanks for this, I'm all set now. I had the settings for lights and beep but didn't realize that there is a master on/off setting as well.
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
