Clarity of menu/navi voice
Old Oct 8, 2008 | 12:04 PM
jjfrehe's Avatar
Hello all - I just purchased a 2005 RL. One thing I have noticed is that it is really hard for me to understand the voice that activates when navigating menus and/or navi. For some reason the voice only comes thru the lower speakers in the front door. I could have sworn that the 05TL I owned a few years back had the voice coming thru the center channel.
Anyone else feel the voice is "muffled" or am I simply going deaf?
Old Oct 8, 2008 | 08:48 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
The sound does come from the front speakers, and if you have the music turned up loud, it will be difficult to hear, but not because it's muffled, but because the rest of the speakers drown out the front.
Taking the volume issue aside, The clarity is fine.
Old Oct 9, 2008 | 07:47 AM
db22's Avatar
No, you are actually going deaf! Is it still muffled with the windows up and the radio off? Do the speakers sound fine on audio playback? Do you use the mans voice or the lady?
Old Oct 9, 2008 | 09:14 AM
jjfrehe's Avatar
Playing music via AM/FM, XM, CD, etc sounds fine. However, with the voice coming only thru the lower door speakers, I just have a hard time hearing it. I am currently using the woman voice.
Old Oct 9, 2008 | 10:26 AM
Ballinger's Avatar
I selected the "Petulant, French Female" voice and it can be so funny: "Fine. You don't wish to turn left for me?"
Old Oct 9, 2008 | 10:35 AM
db22's Avatar
With the radio off is the womans voice loud enough?
Old Oct 9, 2008 | 10:49 AM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
I do not believe the NAVI voice prompts are routed to the center dash speaker.
Have you checked your NAVI Volume? Select the SETUP button on the center stack (lower right side). Then one of the MENU options is VOLUME. What VOLUME is set? I have found I have mine set nearly MAX. And that works fine with my stereo typically set on Volume 14.
You can also raise & lower the NAVI Voice Volume when in operation using the volume control button on the steering wheel. It just will not display the volume setting when doing so.
And just as a personal preference, I find the female voice gets drowned out easier in the moving car, than the male voice, which has a bit more bass and depth. Of course the male voice is no longer enabled in the newer NAVI DVDs.
Old Oct 9, 2008 | 10:55 AM
jjfrehe's Avatar
Ill give that a try. I didnt realize there was a separtate Navi volume.
Old Oct 9, 2008 | 12:13 PM
db22's Avatar
Hence my previous question.
Old Oct 9, 2008 | 05:40 PM
getakey's Avatar
I find the Navi prompts annoying anyway. Do you actually listen to them?
Feb 25, 2020 09:57 AM
TLguy42
Sep 26, 2015 11:27 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
