Centre stack DIY??
Old May 3, 2013 | 11:28 PM
lkoszela's Avatar
Centre stack DIY??
hello!
In upcoming weeks I will be switching out few burned out lights, they are:
-AC / heating lights located just under the centre vents
-both left and right lights attached to seat heaters
Does anyone have DIY on how to take apart a centre stack on a 2008 RL and also what tools I might need?
I've taken out a radio from 2002 TL before if that helps out at all...
Old May 3, 2013 | 11:45 PM
BDoggPrelude's Avatar
I'm like 95% sure those are tiny little LED's that have to be soldered. If you ask me, it's one of those thing where if you have to ask...
Old May 4, 2013 | 10:16 AM
lkoszela's Avatar
with that said, are you trying to tell me that I'll need to replace the whole back panel?
Old May 4, 2013 | 07:47 PM
Carbon Legend's Avatar
Unless you are familiar with smd led and solder reflowing
Old May 4, 2013 | 09:50 PM
mitchkramez's Avatar
I think those lights can be replaced, my dealer replaced them for me when i bought the car (without replacing the panel). There's a thread somewhere in here about switching the panel from a 2005 with one from a 2007 with the fan controls that has some instructions on removal of it and such.
Old May 5, 2013 | 08:29 AM
oo7spy's Avatar
2009+ has the fan controls. OP, the climate control panel is separate from the head unit. The service manual in Carbons signature can tell you how to remove all the trim you need. The radio and nav controls don't need to be touched.
Old May 7, 2013 | 10:17 AM
EL19's Avatar
Someone did a semi DIY on this in here. I'll see if I can find it.
EDIT: here are the threads that describe how to replce the leds
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/f-021-diy-climate-control-bulb-replacement-713113/
https://acurazine.com/forums/2g-rl-2005-2012-76/seat-heater-switch-back-light-how-replace-836177/
And as 007 said, the service manual will tell you how to remove the climate control panel which isn't very difficult
Mike734
Dec 10, 2021 01:25 PM
Dec 7, 2020 05:39 PM
tsx_boy
Dec 13, 2019 08:33 PM
SUPRMN84
Oct 7, 2015 09:46 PM
scionxb3003
Sep 22, 2015 05:28 PM
