Camera in Rear view mirrow
Old Sep 18, 2010 | 08:18 PM
Mr.Tea's Avatar
Is it possible for me to get a rear view camera inside my RL rearview mirror as they have on the MDX inside the rearview mirror.
Old Sep 19, 2010 | 05:27 PM
Ballinger's Avatar
Are you willing to retrofit the camera/rearview mirror from the MDX into your RL? Are you so old and crotchety that you can't turn around to look where you're going?
If your answer to B is "yes", I suggest a positive response for A.
Old Sep 20, 2010 | 10:33 AM
OLD_HATCH's Avatar
lol @ crotchety.
If your willing to go aftermartket it wouldnt be a problem. If you already have the oem back up camera in the nav screen then its going to be a little more difficult.
Old Sep 20, 2010 | 10:24 PM
Mr.Tea's Avatar
Originally Posted by OLD_HATCH
lol @ crotchety.
I dont have either. This will be a totally new setup. Would it be best for me to use the oem setup with the Navigation.
Old Sep 21, 2010 | 07:49 AM
db22's Avatar
The MDX advance system shows you 3 different views with distance markers on a VGA res screen. It's the only system that I have used that doesn't require the occasional use of mirrors and a few looks over the shoulder. The base MDX has the mirrorcam view which is cute but not adequate.
Old Sep 21, 2010 | 10:07 AM
OLD_HATCH's Avatar
Well from what Ive read on the forums if you have an 06+ RL the oem backup can be added since its plug and play. Someone correct me if I'm wrong on this.
Its supposed to be around 500 dollars or so for the kit. It uses the main screen in the dash.
You can go the aftermarket route with an aftermarket mirror with built in lcd, aftermarket camera, and having everything wired in, but I think it will come out to be more than the oem option.
Not to ention on either of these if you cant do the install yourself you will be forking up money for install which can be up there depending which route you take.
Old Sep 21, 2010 | 01:29 PM
white05rl's Avatar
no, adding an aftermarket was cheaper and works really well. Here's the forum link: https://acurazine.com/forums/showthr...ghlight=backup
I have the same camera and it works really well. the price has dropped since the post. i paid about $250 for the interface and $70 for the camera. now i DID do the install myself, but for a total outlay of less than $350 it was worth it.
Old Sep 21, 2010 | 01:31 PM
white05rl's Avatar
the camera is now selling for $59 (that includes shipping). Here's the link:
http://cgi.ebay.com/Car-Rear-View-Wa...item3eff155531
Old Sep 21, 2010 | 02:05 PM
OLD_HATCH's Avatar
he doesn't have navigation, so that might be a problem?
Old Sep 21, 2010 | 06:50 PM
Mr.Tea's Avatar
I do have Navigation, I just thought the mirror cam was much easier to install.
Old Sep 21, 2010 | 07:00 PM
OLD_HATCH's Avatar
well then the nav interface and ebay camera is your best/easiest bet.
I went this route on my RL and works great. If you can do the mounting and slight wiring yourself of course.
Old Sep 14, 2020 | 07:23 PM
Walfunk's Avatar
Not to mention on either of these if you cant do the install yourself you will be forking up money for install which can be up there depending which route you take.
Speaking about the aftermarket rear view mirror. Has anyone installed one of these in an RL? If so, how did you run the wires?
Old Sep 14, 2020 | 10:52 PM
nncy's Avatar
I do have that in my 08 RL. I have the basic RL which doesn't come with camera. So the camera is aftermarket as is the rear view mirror.
Camera automatically invoked when in Reverse
It has the guidelines and decent night vision.
But I didn't install it myself, I had BestBuy install it for me. It is much better/brighter than the factory option using the navi screen.
Old Sep 15, 2020 | 06:38 AM
Walfunk's Avatar
Cool, thanks. Mine has Android and accident avoidance/lane change warning built in. I can run Waze and other apps on it and record front and back video at the same time, etc. Looking forward to getting this installed. How much did Best Buy charge you?
Old Sep 15, 2020 | 07:20 AM
nncy's Avatar
Back then I had Best Buy - Total Tech Support Yearly Membership which was $200 a year so installation labor was free. Otherwise it would have been $150 for the camera and rear mirror installation. If you want to install other things like remote starter and/or microphone for USA Spec Bluetooth streaming, I suggest getting the Total Tech Support Yearly Membership and have all the installation labor done for free.
Old Sep 30, 2020 | 12:17 PM
Walfunk's Avatar
Just an update.
Waze
Will post a pic of the full rearview and the split cam view.
Ran the cables myself. Was a lot easier than I expected; a plastic pry tool made it a breeze.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rocktman1
Oct 31, 2015 02:33 PM
Sep 17, 2015 10:16 AM
dre707
Sep 8, 2015 08:32 PM
