BT45-ACU not fitting 2006 RL
Old Oct 15, 2018 | 06:16 PM
sqrtal's Avatar
6th Gear
Can someone help me understand why the BT45-ACU does not fit my 2006 RL with Navigation. The connectors on the BT45-ACU are bigger than the ones on my actual unit.
I have setup a return with Amazon. I'm thinking that I will need the BT45-HON3.
Any ideas why the BT45-ACU doesn't work?
Old Oct 15, 2018 | 06:18 PM
https://www.usaspec.com/p-314-bt45-acu.aspx
Because you're supposed to plug it into the XM tuner. Are you trying to plug into the radio?
Old Oct 15, 2018 | 06:21 PM
sqrtal's Avatar
6th Gear
That's where I am plugging it into. Left rear panel of the car.
Old Oct 17, 2018 | 05:14 PM
sqrtal's Avatar
6th Gear
***Update and resolution***
I reached out to USA Spec. After some troubleshooting they were able to determine that my RL does not have the "tech package". The BT45-ACU is for the RL's with the Tech Package even if you have navigation.
Currently in the process of returning the ACU for the HON3.
Issue resolved.
Old Oct 17, 2018 | 08:05 PM
projektvertx's Avatar
Good to know, did not realize that a distinction existed with that unit.
Old Oct 18, 2018 | 10:29 AM
ksu1018's Avatar
I had the ACU and it worked fine on my 05 RL with TECH. I got the BT45-HON3 only to have bluetooth. Does not work. When I select the XM button to change the source/mode my radio head unit does nothing. I have sent USA spec the complaint. I am waiting for a reply. I have hooked it up correctly.
Old Nov 4, 2018 | 08:07 PM
truonghthe's Avatar
lol all 05-06 RL does have navi and there are no such thing as "Tech pacakge" back then. BTW my 06 RL has ACU-45 and it fit no problem.
Old Nov 8, 2018 | 07:39 PM
sqrtal's Avatar
6th Gear
I'm thinking my unit was replaced or something.
I received the BT45-HON3 today and it does not fit. The pin counts look to be the same but the order is different. I have attached a photo of my XM Tuner here so you can see.
When I had the BT45-ACU, the connector had too many pins. I think the ACU has 20 pins and my connector has 14 pins.
Any ideas?
XM Tuner unplugged/
Old Nov 10, 2018 | 11:50 AM
napol's Avatar
The bt45-acu should have been a 14-pin connector, fits my 05 rl w/nav
Old Jan 2, 2019 | 09:44 AM
MITIA's Avatar
It works perfectly on my 2006RL with Navigation, see MDX install on Utube:
Old Feb 26, 2021 | 11:02 AM
HenryW's Avatar
what is the tech package for an 05 RL?
Garci411
4G TL Problems & Fixes
Jan 26, 2017 12:54 AM
Mighty T
Feb 24, 2013 07:40 PM
2gns4me
Nov 18, 2008 02:51 PM
yue3759
Jun 18, 2008 04:21 PM
