BT45-ACU not fitting 2006 RL
Can someone help me understand why the BT45-ACU does not fit my 2006 RL with Navigation. The connectors on the BT45-ACU are bigger than the ones on my actual unit.
I have setup a return with Amazon. I'm thinking that I will need the BT45-HON3.
Any ideas why the BT45-ACU doesn't work?
https://www.usaspec.com/p-314-bt45-acu.aspx
Because you're supposed to plug it into the XM tuner. Are you trying to plug into the radio?
projektvertx (10-17-2018)
***Update and resolution***
I reached out to USA Spec. After some troubleshooting they were able to determine that my RL does not have the "tech package". The BT45-ACU is for the RL's with the Tech Package even if you have navigation.
Currently in the process of returning the ACU for the HON3.
Issue resolved.
Issue resolved.
I had the ACU and it worked fine on my 05 RL with TECH. I got the BT45-HON3 only to have bluetooth. Does not work. When I select the XM button to change the source/mode my radio head unit does nothing. I have sent USA spec the complaint. I am waiting for a reply. I have hooked it up correctly.
lol all 05-06 RL does have navi and there are no such thing as "Tech pacakge" back then. BTW my 06 RL has ACU-45 and it fit no problem.
I'm thinking my unit was replaced or something.
I received the BT45-HON3 today and it does not fit. The pin counts look to be the same but the order is different. I have attached a photo of my XM Tuner here so you can see.
When I had the BT45-ACU, the connector had too many pins. I think the ACU has 20 pins and my connector has 14 pins.
Any ideas?
XM Tuner unplugged/
Any ideas?
XM Tuner unplugged/
yue3759
06-18-2008 04:21 PM
