Blackberry 8703e and HFL
Old May 24, 2007 | 05:33 PM
FredS's Avatar
Just purchased a Blackberry 8703e with service with Verizon and had no problems pairing the phone but it cycles from connection established and connection lost. Anyone solve this issue. Thanks!!!!
Old May 24, 2007 | 06:30 PM
sequoia's Avatar
tuning / modding newbie.
i have the same phone on sprint and it only happens sporatically, i think it's when you have a third part app (mine is JiveTalk) that maintains a constant signal with a server (other than your push email) what I've done in the past that alleviates it immediately is cycle bluetooth on and off, an then it's back to normal. I'd get rid of the program causing the interferences but I use it way too often, and it only happens to me once in a great while. (maybe once or twice a month)
another way to fix is dial out from your phone, and then transfer it to HFL, it wont cycle after that.
good luck
- sequoia
Old May 24, 2007 | 06:39 PM
jcbridges's Avatar
Wheelin' Dealer
The most common cause of this with Blackberry devices is adjusting the Bluetooth settings on the phone for the connection. Once paired, use your jog dial to select HandsFreeLink. Then adjust the settings so that the connection is trusted and select encryption off.
Old May 25, 2007 | 02:07 PM
CumbaJ's Avatar
These are my Bluetooth settings on my Verizon Blackberry phone:
Trusted: YES
Encryption: ENABLED
Echo Control: AUTOMATIC
Never had a cycle connection issue.....
Old May 25, 2007 | 09:20 PM
FredS's Avatar
The older Blackberrys seem to work but the 8703e has a problem. Two friends with this same phone and Acura's are having the same problem. Anyone solve this problem
Old May 25, 2007 | 09:21 PM
FredS's Avatar
Trusted: YES
Encryption: ENABLED
Do you have an 8703e Blackberry?
Old May 27, 2007 | 03:49 PM
CumbaJ's Avatar
Sorry - i have the 7130e. I'll have to keep my eyes on this thread cause i was going to upgrade to the 8703e
Old May 27, 2007 | 04:01 PM
sequoia's Avatar
it really isn't an issue (at least for me) it happens so rarely that it's never really been an issue. I had more problems with my samsung a900, and my treo more than I had with my blackberry. I can honestly say it's been the best phone that I've used with my HFL.
Old May 27, 2007 | 04:03 PM
sequoia's Avatar
Trusted: YES
Encryption: ENABLED
my connections are exactly the same.
(i don't know if i'd want encryption off on a bluetooth device...)
mada51589
Jan 9, 2025 04:40 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
cali boy 91
Sep 19, 2015 01:57 PM
Markbby06
Sep 17, 2015 02:30 PM
