Blackberry 8703e and HFL
Just purchased a Blackberry 8703e with service with Verizon and had no problems pairing the phone but it cycles from connection established and connection lost. Anyone solve this issue. Thanks!!!!
tuning / modding newbie.
i have the same phone on sprint and it only happens sporatically, i think it's when you have a third part app (mine is JiveTalk) that maintains a constant signal with a server (other than your push email) what I've done in the past that alleviates it immediately is cycle bluetooth on and off, an then it's back to normal. I'd get rid of the program causing the interferences but I use it way too often, and it only happens to me once in a great while. (maybe once or twice a month)
another way to fix is dial out from your phone, and then transfer it to HFL, it wont cycle after that.
good luck
- sequoia
good luck
- sequoia
The older Blackberrys seem to work but the 8703e has a problem. Two friends with this same phone and Acura's are having the same problem. Anyone solve this problem
Originally Posted by CumbaJ
These are my Bluetooth settings on my Verizon Blackberry phone:
Trusted: YES
Encryption: ENABLED
Echo Control: AUTOMATIC
Never had a cycle connection issue.....
Trusted: YES
Encryption: ENABLED
Sorry - i have the 7130e. I'll have to keep my eyes on this thread cause i was going to upgrade to the 8703e
Trusted: YES
Encryption: ENABLED
Trusted: YES
Encryption: ENABLED
(i don't know if i'd want encryption off on a bluetooth device...)
mada51589
05-03-2022 08:54 PM
phillyguerrilla
09-26-2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
09-19-2015 08:41 PM
