Battery Cable Reset
Old Feb 9, 2012 | 10:19 AM
HEAVY_RL's Avatar
Battery Cable Reset
Got this from the OEM Acura Parts Facebook page and thought it may be useful for us RL owners.
Tim Oem Acura Parts
CAR CARE TIP: Many automotive systems today rely on software. Should that software develop errors, which can happen from something like a low battery or interrupting a learn procedure, it can cause all sorts of odd electrical problems that can be hard to troubleshoot. If you’ve got such a problem, try doing a battery cable reset; it just might do the trick. A battery cable reset forces all capacitors to discharge faster, and clears and resets most control unit volatile memory. It’s like removing and reinstalling the battery in a cell phone that’s acting weird. Before you start, make sure the battery is fully charged. A low battery can cause problems with electronics. Then, get the anti-theft code and write down your audio presets. Now, follow these steps:
1. Turn the ignition switch to LOCK (0), and remove the key. This lessens the chance of voltage spikes.
2. Disconnect the battery cables—negative cable first, then positive.
3. Short the battery cables together with a jumper wire.
4. Turn the ignition switch to ON (II), and wait 10 minutes.
5. Turn the ignition switch to LOCK (0), and remove the key.
6. Remove the jumper wire, and reconnect the battery cables—positive cable first, then negative.
7. Do the required reset/learn procedures for the vehicle you’re working on.
8. Enter the anti-theft code, and restore your client’s settings.
(Acura ServiceNews, January 2012)
Old Feb 9, 2012 | 01:32 PM
oo7spy's Avatar
Interesting. Turning the ignition on never occured to me.
Old Feb 9, 2012 | 01:39 PM
HEAVY_RL's Avatar
yep, the shorting the wires deal is why I thought it was valuable... these guys that say a battery reset doesn't work might still have a charge in the system.
Old Feb 9, 2012 | 02:58 PM
EL19's Avatar
Didnt think of that either. Thanks Heavy
Old Feb 9, 2012 | 10:37 PM
oo7spy's Avatar
I have heard of the shorting idea before, and it makes complete sense. Many electronics have a jumper that can be moved and used to reset everything. However, turning the car "on" is an interesting idea. I can't quit wrap my head around the idea, but I also don't try to understand the weird shit that electronics do. The number one step in debugging is to turn it off and then back on.
Or if you are really clueless, making sure it's plugged in.
Old Nov 12, 2019 | 06:09 PM
wilson chong's Avatar
I joined this forum to thank you. I had endless battery problems with my 2012 Acura TL. Changed batteries 3 times in 3 years. Low voltage alerts, sluggish starts in the mornings, random dead battery which could occur any time. I tried your fix (and was skeptical) and immediately all my problems went away. No more voltage alert. No more sluggish starts.
Thank you so much. Something so simple fixed all my issues.
Old Nov 25, 2019 | 06:06 PM
TonyCD's Avatar
Fascinating. But I wonder how that "Remove the key" stuff is to be applied to keyless systems like ours. Just ignore that part?
Old Nov 25, 2019 | 06:17 PM
deepa1600's Avatar
RL's key cover can be removed by inserting physical key from bottom of the knob and then regular ignition switch is visible once you remove the plastic cover.
Old Nov 25, 2019 | 06:24 PM
TonyCD's Avatar
Thanks. I know that, but that alone would have no electrical effect at all; it's just a piece of plastic trim.
Old Nov 25, 2019 | 06:27 PM
deepa1600's Avatar
Turn the ignition switch with physical key after removing plastic cover. Because the switch will not turn if the plastic piece is present without power i think.
Old Jul 2, 2024 | 08:33 PM
RonDZee's Avatar
6th Gear
Hey,
BIG thank you to HEAVY_RL…
This was my journey...
So, I went from incandescent turn signals and reverse lamps to LEDs. The reverse went without a hitch. The ORIGINAL LED turn signals experienced the common “hyperflashing” issue due to the low wattage pull. I don’t have a flasher relay for this model, all is built in to the electrical system, so that was a bust.
So, I find that I can install 21w LEDs and this would fix the issue. Great idea but no so good. I installed them one evening and it went fine. No hyperflashing, just the normal speed as usual. All is good and I come out later that evening to a nightmare…
All was good when I first came out and checked them again without turning on the headlamps. They flashed fine… Then I turned on the headlamps and all went to pot. Left turn signal went fine at first, then the right turn signal was also the four way flashers… Then all of a sudden the wipers came on and then a few moments later the window washer fluid came on and would not turn off…
Needless to say, I was just floored. Nothing else was installed but the new 21w LED turn signals. I knew it had to do with them, but I was not aware to the extent that this model was wired by the manufacturer. So long story short, I researched this issue on Google and this post came up…
I did what it said and left them jumped, after the 10 minutes, when I changed back to the original incandescent bulbs. It worked like a charm…
Now I believe that armed with this knowledge, I can re-install the 21w LEDs after I reset it again and it will read them as part of the system without any errors, but we’ll see and report back.
I appreciate the knowledge here, as I am a first-time owner of a 2012 Acura TL 3.5L with Advance package 6 speed transmission. You guys ROCK!
m015094
Oct 5, 2017 10:58 PM
jaydubz
1G RL (1996-2004)
Apr 22, 2016 05:03 PM
jdm_fanatix
4G TL Problems & Fixes
20
Jul 7, 2015 06:21 PM
08A-SPEC
Dec 8, 2009 01:34 PM
klister
Sep 1, 2005 10:11 PM
