3G iPhone
3G iPhone
When activating the HFL the volume shoots up. I have a 3G Apple iPhone connected. Previously I had a Motorola Razor and di not have this problem. If my radio volume is at 11 and I activate the HFL the volume increases to 30. Is there a setting I need to adjust to keep this from happening?
the volume settings for the radio and HFL should be separate. When you activate HFL, turn down the volume to desired level. It should remain at that level unless you change it. Also, it should not affect the radio volume.
If this is not the case, something is wrong.
I understand the seperate volume control for the HFL vs radio. It just that each time I activate the HFL the volume immediately jumps up to 30+ (very loud for the voice interaction) even when I turn down the volume on the radio to zero prior to activating the HFL. i would like the HFL to come on at 12-15 on the volime level. Even if I disconnect the HFL on volume 15 the next time I activate it the volume jumps right back up to 30.
It should, being a new product but you never know with Palm.
Ive been a Palm user for over about 4 years (Treos 650/700p/755/Centro) and they always seemed to be behind when it came to bluetooth. Lets hope with the Pre they actually get it right the first time.
This is a whole different problem if you have already set the HFL volume to 0 and when you reactivate it, it is shooting to 30.
My unlocked GSM Treo Pro works fine with the HFL system. It will not connect to AcuraLink but works well with HFL.
mlody
Dec 4, 2019 02:11 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
Barb Jackson
Sep 15, 2015 02:27 PM
IndycarFaster
Sep 11, 2015 02:52 PM
