05 rl engine noise
Old Dec 15, 2010 | 05:22 PM
acura920's Avatar
4th Gear
05 rl engine noise
i bought my 05 rl in 07 and it was very quiet when running. now at 1000,000 miles its very noisy when running. Whether summer or winter. any suggestions?
Old Dec 15, 2010 | 07:54 PM
rmjse's Avatar
I would recommend doing the 105K mile service. You are almost do for it, you might as well do it now. Its mainly a timing belt and water pump replacement, but they also do a valve adjustment which should reduce engine noise.
Old Dec 16, 2010 | 10:22 AM
db22's Avatar
After the first million miles you should up the viscosity and change the oil!
Old Dec 16, 2010 | 10:34 AM
acura920's Avatar
4th Gear
Hey, thanks for the info. I'm going to do the 105k maintenance now. Hope it cures.
Old Nov 5, 2012 | 10:19 AM
jamesdcarrillo's Avatar
5th Gear
RL Engine Noise
Hi,
This is my first post, but I would like to say 'Thank You' for coming close to the problem I'm having with my 06 RL.
My engine started making a higher-pitched sound that was louder than the normal engine noise. It became louder as I accelerated. I had the timing belt/water pump changed along with whatever came with that $1,600 bill at the dealer.
The noise is still present. It almost sounds as if something that is spinning is about to go bad. I've read it could be the tensioner, but I'm wondering if this is a common problem with the 2nd Gen RL and if anyone out there has had a similar problem.
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
