Wiper Blades
Old 02-14-2008, 06:23 AM
bearingman07936's Avatar
Wiper Blades
I just went onto Rain X website to see which blades fit my 2006 RL and they seem to have skipped the 2005 and 2006 years for the list. Anyone out there have Rain X blades on their 2006 RL, and if so, which year fits?
Thanks.
Old 02-14-2008, 07:57 AM
dwboston's Avatar
Thanks.
I noticed that the other day. The 2007 blades are the same size as the 05 and 06 ones - they should match.
Old 02-14-2008, 09:33 AM
Rob144's Avatar
Are you thinking of replacement inserts or replacement blades? These days its hard to find just the rubber insert. Are there any aftermarket replacement inserts?
Old 02-14-2008, 09:37 AM
dwboston's Avatar
Yes. I use the PIAA Super Silicone inserts. They slide right in. I bought the latest set at Autobarn.com. Much better than the stock wiper inserts.
Old 02-14-2008, 10:58 AM
ed111's Avatar
dwboston, do the PIAA silicone inserts slide into the RL's OEM wipers and lock into place? The autobarn website states that the PIAA inserts are for PIAA blades only?
Old 02-14-2008, 11:05 AM
dwboston's Avatar
Yes - they slide in and lock into place. The part of the blade that holds the insert is identical between the RL OEM wipers and the PIAA blade. I've replaced the inserts twice on my RL's and also on my wife's MDX with no problem.
Old 02-14-2008, 11:21 AM
ed111's Avatar
OK, thanks. I may give them a try.
Old 02-14-2008, 12:07 PM
getakey's Avatar
I went to autobarn website and they don't list the blades for RL years 2005+
What size insert did you get?
Old 02-14-2008, 12:48 PM
dwboston's Avatar
Assuming that you are talking abou the PIAA's, you don't need blades, just the inserts. 28" for the driver's side and 19" for the passenger side.
Old 02-14-2008, 02:21 PM
lland's Avatar
I have PIAA Super Silicone replacement inserts. The best wipers I've ever had and I can't imagine ever using anything else. After more than a year, they still wipe clean and are silent. I bought them from CarDomain.com but I don't think they carry just the inserts any more. Autobarn however, does...Driver's side (28") is PIA94070 and the passenger side (19") is PIA94048.
LL
Old 02-14-2008, 02:29 PM
getakey's Avatar
thanks dw and lland
Old 02-14-2008, 03:12 PM
Treblig's Avatar
Question
LL
Don't they come with some glass treatment that you have to apply to the windshield?
Old 02-14-2008, 03:30 PM
dwboston's Avatar
Not the PIAA inserts.
Old 02-14-2008, 08:01 PM
jfprl's Avatar
I bought the Rain-X wipers at walmart for about 8 bucks each. Removed the insert and replaced it into the original wiper frame. Worked great for about $17 bucks total.
Old 10-07-2008, 01:51 PM
Ballinger's Avatar
I couldn't find the PIAA Super Silicone wipers locally and, knowing they add like 35hp to my car , I had to have them. So, I ordered from Autobarn and everything was going fine until I decided to buy another item I can't find locally: the rear window wiper for our Escape. At that point, the Autobarn system glitched and I had to get on the phone with a quaaludian service rep that took 15 minutes to find the items even as I read him the part numbers from the site. Painful.
The wiper inserts for the RL are in stock and cost 9 and 7 dollars, respectively.
Old 10-12-2008, 01:22 PM
medrxman's Avatar
LL
do you have to remove the blades from the car to replace the inserts ?
Old 10-12-2008, 04:30 PM
lland's Avatar
I did becasue I found it to be easier but others haven't so not necessary. Just a couple of screws on each.
LL
Old 10-22-2008, 07:42 AM
4th Gear
jspelman13's Avatar
Is there a trick to replacing the inserts? I have not done that before but would gladly do so to save some $$. Thanks for your help.
Old 10-22-2008, 07:50 AM
Storm982's Avatar
i would remove the blades just so you aren't messing with the wiper arm in the up position only to have it fall back onto the windshield only to have it crack the glass... yeah i made that mistake on my mom's car... i would also put a towel or something else on the glass so the wipe arm has something to rest on other than glass while your putting the new inserts on. just my 2 cents though.
Old 07-08-2009, 11:07 PM
Don Melcher's Avatar
My wife's 07 needed new blades. The engineer who came up with the wiper design should be shot. Replacing refills is a pain in the A##!!! Why did they have to re-invent the wheel. I can change the blades on my 97 Ford van OR my two 69 Porsches in 5 minutes without any tools.
As Bugs Bunny would say - What a maroon!!!
Old 07-09-2009, 11:46 AM
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
It is a pain in the butt to change the wiper blades on the RL. I had to do it twice and it took about ten minutes, vs. a couple of minutes on my other cars.
Old 07-09-2009, 04:29 PM
037's Avatar
took mine to the dealer, they replaced them for free and even dumped my old one's even though I asked them to trunk them just in case.
and when I say free, I mean I bought a new set of PIAA silicone inserts and they installed em...
Old 07-10-2009, 12:34 AM
gbriank's Avatar
It took me about 15 minutes to get the new PIAA's installed. Even though it is a pain in the "you know what", its better than paying the $35 my dealer asked to do the same.
Old 07-10-2009, 12:21 PM
guss_90's Avatar
It's hard to find these blades. And if U do find them, It;s hard to change them too. But " A Clean windshield with good vision in a rainny day if goodf to have.
Old 07-10-2009, 01:23 PM
gbriank's Avatar
www.autobarn.com
Very easy to find. Make sure to measure your wipers first to get the correct length. Oh yeah, look online for coupons. I think I found one for free s/h.
Old 10-04-2010, 05:36 PM
Ballinger's Avatar
moist
The moisture we're getting in San Diego skies reminded me of how well the PIAA wipers work and how very worth-it it was to go through the effort of buying these blades. Perfect performance.
Old 12-20-2010, 06:35 PM
Ballinger's Avatar
grinning and relaxed
All this SoCal (actually, AllCal) rain has me again reminded about how well the PIAA wiper blades work. So, if you're reading this and not stoked with your wiper performance, scroll up, get a link and get them ordered. This is a simple, cheapass upgrade that you'll enjoy every time the blades swipe your windshield.
Old 12-21-2010, 08:15 AM
wcoy's Avatar
Put my new PIAA's in last night, first time I have changed them on the RL myself. Took a little time to figure it out but now that I know how it's actually quite easy, just grasp the locked side hard and pull.
Old 12-30-2010, 11:20 AM
DanL07RL's Avatar
I've no end of problems with wiper insert replacements, plus I discarded my metal "spine" when the original set was trashed.
I'll try the PIAA brand. Thanks for the tip.
Old 01-04-2011, 09:17 PM
037's Avatar
autobarn did not have PIAAs in stock, ordered from tire rack for $30 shipped...retardical for a pair of inserts but I didn't want to waste time waiting for shipping via amazon.
Reason for purcahse? I had my car serviced and they removed my 2 year old PIAAs and replaced em with brand new Honda wipers.
One wipe and a layer of thin gray matter covered my window. Game over crappy wiper!
Old 01-04-2011, 11:55 PM
ichi d's Avatar
i find the oem inserts work really well. im now leaning on the piaa for next time to try em out and see if theres really much of a difference.
Old 01-05-2011, 04:56 AM
lland's Avatar
May be expensive for a pair of inserts but I've had mine on the car since early 2007 and they're still going strong.
LL
Old 01-05-2011, 07:28 PM
2005 RL
racerrl's Avatar
I had my dealer install my new PIAA's at my oil change last week, (free install), and so far I love them too!
Old 01-06-2011, 06:03 PM
rlerman's Avatar
autobarn does not have the 28" size available
Old 01-06-2011, 06:56 PM
Mr.Tea's Avatar
Please go to Amazon, Total cost 20.00 shipped to me. I just installed them in less than 5 minutes. They came UPS in 2 days.
PIAA 94070 Silicone Wiper Blade Refill - 28" $8.49
PIAA 94048 Silicone Wiper Blade Refill - 19" $6.37
Old 01-06-2011, 08:37 PM
white05rl's Avatar
Thank you, Mr Tea. I just ordered mine, your part numbers made it very easy.
Old 01-07-2011, 06:48 AM
Mr.Tea's Avatar
No problem brother!!
Old 01-07-2011, 06:03 PM
rlerman's Avatar
Yep, that's what I did last night. Had to add $10 to the order to get free shipping. they will be here Monday.
Old 01-08-2011, 12:44 AM
23109VC's Avatar
I just did mine and didnoem refills. 14 bucks at dealer and they are easy to put on.
Old 01-08-2011, 11:24 AM
037's Avatar
I'm bout to take the oem wipers off, 5 bux, anyone? Blazing?
Quick Reply: Wiper Blades
