Where can I buy an 05 RL Fog Light
Here are some Sylvania H 11 Bulb $ 33- Halogens
since Low Beans HID are so bright. Dont buy some cheap H11 bulbs for 6 dollars or 12 bucks, they dont last long....
http://cgi.ebay.com/ebaymotors/H11-S...Q5fAccessories
Or you cna spend $ 110 for HID Fog light kit.
Chapter Leader (Chicago)
i need the housing too...
my lens cracked. and i need to get that repaired. and the only way to repair it is by replacing the housing sucks i know.
I would search. I recall someone replaced their lens only by getting it cut at a glass place, and sealing it themselves. There is a thread somewhere.
i am also looking for fog light housing as well as i have a crack in the lens.
so far the only thing i can find is on ebay hella light brand, which isn't really what i'm looking for.
Proboscis-free zone
My right front fog light also has a cracked lens. I'm going to use the fog light protective cover I got with the headlight protective covers I recent bought, to see if they prevent further damage. Thinking it going to have to warm up a bit for this project to work.
I thought a rock hit it or something but sure enough my right lens is also broken. It sure sounds like a factory defect. Mine has been broken for years but the bulb is still working.
Because depending on the type of crack it is, some clear epoxy followed by a polish of the lens might work as a cheap/decent loking fix. Only in certain scenarios though.
Randy is the Future
i just bought some from advanced auto parts for 24 bucks...... One is out already don't know why and i did the install myself.
Here is a potential DIY, granted for a TL, but it might work
https://acurazine.com/forums/2g-tl-1999-2003-98/lexan-fog-light-fix-painted-fog-lights-diy-694354/
Here is another, by a departed member, granted, not for an RL either.
https://acurazine.com/forums/2g-rl-2005-2012-76/broken-fog-light-lens-500116/
Although it would seem as if the cheapest would be to replace with 3000K HID as 037 did.
Did the Headlight and [cracked]fog light protectors today. Took about an hour, which included the turn signal protectors. The fog light crack is still there , but no water will get to the lamp. Cost was $49.95 and one hour of labor.
Did you buy the kit online? If so, could you please share a link?
Glad to share www.drivingcomfort.com
They even included protection strips for the turn signal lights which was not mentioned in the ad. I used a hair dryer and it was more than sufficient, even at our 40*F temp. today. I started with the uncracked fog light and then went to the turn signals to get the feel of the application.
My drivers side fog light recently cracked and I'm possibly going to see if I can replace just the glass without replacing the entire fog light. A question though...can the glass be replaced with plexiglass? I know home depot sells sheets of this, but didn't know if it would be advised to only replace with glass due to heat or other factors I might not know of. Anyone have any insights or advice? If plexiglass could be used, I would think the replacement would be much easier, but not completely sure.
so bogey did this work out for you.. .shit i need to do that if it did. i want to put my HID kit on but i am afraid that they will burn out with some water getting in thru the crack...
but let me know...
but let me know...
Glass is much stronger than the plexiglass they sell at home depot. Now if it was the same type of platic used in headlights it would be a different story. Plexiglass isn't as translucent and could melt as well.
there seems to be alot of people with this problem, any chance of a recall on too thin a glass maybe?
It does seem like quite a common problem...it would be nice if there were a recall on it.
BTW, $188 was not the offered price a couple of years ago, it was more like $350 if memory serves.
Cracked Fog light repair
chip in the center. It was very easy installation and you will have the additional benefit of protecting the headlights if you buy the kit. Good Luck!!!
Former Sponsor
I should have made a DIY as its very easy to do. I replaced the lens yesterday on my brothers 05 RL. Just like the 2G TL the lenses for OEM fogs are made out of glass and eventually they will break due to a rock impact.
You can replace the lens with Plexiglas , not just any regular Plexiglass though, you'd need Lexnan MR-10 plexiglass. Its the same stuff headlight lenses are made out of, its good against UV rays, high heat from fog light output and also is scratch resistant to a certain extent.
A sheet of MR-10 can be picked up from ebay for around $30 or so which would be good for two fog lights. I had some left over from another project which I ended up using.
-- Break off all the old glass, be careful and wear gloves.
-- Clean the silicon channel.
-- Put the fog light housing onto the plexi sheet, draw the outline so you know where to cut the plexi.
-- Cut the plexi using dremel or a hack saw.
-- Fill the silicone channel with RTV black, make sure that the silicone level is not above the inner fog light rim, this will make sure that once you install the lens the silicone wont ooze into the fog light.
-- Take off the protective film off of the plexi.
-- Install the plexi onto the fog light, apply some electirical tape over the lens and around the fog light to keep the lens in place.
-- Wearing a glove, use your finger to fill the gap between the lens and the fog light with the RTV silicone, while filling the gap you'll notice how the silicone wont ooze into the fog light a the inner lip of the fog light will prevent it from happening.
-- Give the silicone 24 hours to cure before re-installing.
The whole job took me an hour to complete, I just had to do one fog. The only bad part is that one light looks brand new now and the other looks roughed up. Once the other one breaks I'll do the same thing on that one and may be write another DIY with pictures.
So just out of curiosity, I know in general, Lexan is a polycarbonate resin, and that polycarbonate has a high impact resistance, and is a natural UV filter. I do not know about heat resistance...will the fogs do anything to the Lexan, since halogens burn pretty hot. I do know that Lexan is not that scratch resistant, so I am wondering if you plan to put a protective film over it to protect the clarity, or just take your chances? I suppose you can always use one of those headlight cloudiness repair kits on it.
Former Sponsor
I dont intend on putting any sort of film on them as I can always change the lens if it gets too roughed up. Also, yes, the MR-10 isnt scratch resistant but does resist normal swirls etc better than regular plexi. Think of it as the same plastic as is used for your headlights, what ever your headlights can bare the MR-10 can bare the same.
https://acurazine.com/forums/2g-rl-2005-2012-76/g-009-diy-rl-fog-light-glass-replacement-769528/
Lexans can handle heat from regular halogen at 35 and 55 watt, I had them on my 2G TL for more than 2 years without any issue and for some time I also ran an HID kit in the fogs as well.
unofficial HONDA rep
you can get a replacement oem foglight lens for about $125. try http://acura.bernardiparts.com/
then on the top choose acura parts & accessories you can choose by VIN# or make and model
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
