Warranty Maintenance
2005 RL 35K miles - Just had a sudden stoppage (no noise, just quit).
All valves were replaced (under warranty), but no one seems to know why the valves were "bent." Anyone have this problem? Note: The timing belt showed wear, but was not broken. Performance was excellent until the engine stopped.
RL Valves
Originally Posted by fatty
Are you original owner?? Drive the car hard??? Ever rev the limiter in manual mode??
One remarkable thing is the stoppage was precisely at the end of an ILS runway. Could the engine controls have been modified by some sort of radiated signal related to the airport's radio/navigation/control systems?
An attempt to restart the engine did give up a "singing" sound, but the engine did not restart and the car was towed to the shop.
The shop said they found compression issues and "some" bent valves. They decided to change all 24. They also said there was no visible damage to the pistons.
Can radiated signals effect the computer? What are some likely results? Are these results apt to bend valves?
th
Had to be a timing issue, almost positive it is mechanical, your dealer almost has to know because Honda will want to know. Can you talk to the tech or service manager, we would like to know?
thanks
thanks
Consult with dealer/Honda
thanks
thanks
Worrisome is the notion that after the warranty there may be more issues.
th
