Vtec
Old May 10, 2011 | 07:21 PM
thanklessjob's Avatar
Cool Vtec
When does the Vtec kick in with the RL?
at 4800 rpm, at 5000rpm?
Also why does the transmission shift early at 6400 rpm when the throttle is fully open?
In the manual mode, it will go all the way to about 6800 rpm.
Is there any way to adjust when Vtec kicks in and when the transmission shifts via an aftermarket ecu program of some kind?
Thanks all, in advance.
Old May 10, 2011 | 07:58 PM
wackjum's Avatar
The 3.5 engine VTEC changeover is at 4950 RPM.
I can't think of any reason to change the engagement RPM if you are running stock.
Old May 10, 2011 | 09:03 PM
VQPower37's Avatar
im sure there is a way to change it ... prob not cheap
Old May 11, 2011 | 07:42 AM
EL19's Avatar
VAFC-Neo will allow you to change the vtec engagement RPM. Runs about $300 new and you'll need someone to splice into the ecu for you unless you get someone to make you a PnP harness
Old May 11, 2011 | 07:59 AM
tnobori1's Avatar
Missing my
But seriously, why? I could see the need if you were heavily modded, but otherwise I would trust the Honda engineers to choose the right engagement point.
Old May 11, 2011 | 08:40 AM
037's Avatar
037
the key is the right engagement point for fuel economy, this is no race car.
Old May 11, 2011 | 09:51 AM
xdarkne55x's Avatar
/\ what he said.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
