Tpms
Old Nov 5, 2017 | 09:55 PM
Acura05rl's Avatar
Tpms
My drivers side TPMS is reading 58 but then reads correct tire presure after I drive for a few. Is this normal? It’s only that wheel.
Old Nov 6, 2017 | 01:13 AM
Crashmaster's Avatar
Nope, not normal. I assume you tested the tire pressure with an accurate tire gauge. Often when the battery starts to go, you will get unusual readings. The batteries in the TPMS last around 7 or 8 years and it appears you could be at the end of your battery life. Has this driver side wheel had problems in the past, not TPMS, but with slow leaks or a nail in the tire? The more one wheel continues to transmit TPMS trouble, the quick the battery will wear out.
Old Nov 6, 2017 | 08:06 AM
Acura05rl's Avatar
okay. Thanks for the response. Can I buy a one from ebay as opposed to dealer? Should I replace all or just that one. I recently got all my tires replaced, but I was present when they were changed and saw no damage done to sensor.
Old Nov 6, 2017 | 08:26 PM
truonghthe's Avatar
its your TPMS on the way out, mine didn't do that. It decide to throw me a message "check your TPMS" I already know the TPMS sensor but it kinda surprise me since the guy who I swap Aspec wheel from had 185k miles on the clock and being 11 years old.
Old Nov 7, 2017 | 03:32 AM
Yes, you can go to Ebay and get a TPMS sensor much less than it would cost you at an Acura dealer. Keep in mind that when one sensor goes out, the batteries in the other sensors are usually pretty much not far from failing too. You might want to just bite the bullet and replace them all.
Old Nov 17, 2017 | 08:13 PM
Acura05rl's Avatar
The dealer is showing part number 06421-s3v-a04 as tpms for $26.09 the illustration number 1. Is this the right part? If it is at that price is not bad. Why are people saying they cost $40-$70 each?
Genuine Acura OEM Automotive Parts Catalog - Bernardi Parts
Old Nov 18, 2017 | 04:13 AM
Labor for this can be expensive. If you are needing new tires, it would make sense to combine these two jobs to save money. The prices for TPMS sensors have dropped for older model cars because there are aftermarket companies making them much cheaper so the OEM had to lower their price.
Old Nov 18, 2017 | 08:32 AM
Acura05rl's Avatar
I ended up buying the TRW’s sensors on ebay to save some money since they will do the same job as oem. I had new tires installed at a local shop about a month ago where I know the owners for a while so they can give me a good price for install. Doesn’t seem difficult from the videos I’ve seen on youtube. I saw one guy do it with the tire on rim, but just deflated to get the sensor in. As far as relearning, I just have to drive a few miles correct? Btw I should’ve done this when I installed new tires. Live n learn.
Old Nov 18, 2017 | 12:44 PM
To my understanding the TPMS sensors are not plug and play but must be coded to the computer. Most all tire shops should have the equipment to do this.
Old Nov 18, 2017 | 01:04 PM
Acura05rl's Avatar
This is what I read:
Acura RL TPMS Reset Procedure
Relearn Code: AC-1
Relearn Procedures: Ensure all tires are inflated to the pressure listed on the tire placard. Drive vehicle at speeds above 15 mph for a minimum of 40 seconds. Sensor ID's will be learned automatically.
Old Nov 18, 2017 | 01:37 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
^^^^ Correct - Acura sensor (assuming the correct ones are purchased will automatically sync up after a few miles of driving.
Old Nov 22, 2017 | 06:08 PM
Acura05rl's Avatar
Before I start a new thread I wanted to confirm that these are plug and play:
https://m.ebay.com/itm/4-x-Tire-Pres...pid=1953386676
I just got them today and before I get them installed just wanted to make sure.
schen72
1G RDX Problems & Fixes
20
Jan 26, 2021 12:34 PM
mmret
3G MDX (2014-2020)
Oct 13, 2020 10:26 AM
falconwing
May 3, 2017 09:34 AM
VTECMAN
Dec 30, 2016 11:49 AM
bigbluecanuck
Dec 2, 2016 12:22 PM
