Timing belt service
Timing belt service
Can someone please list what should be included in the timing belt service?
I've searched but only get bits and pieces and not really full list.
I asked at Honda dealer and I was given timing belt service price of $899.95 and they did confirm it includes water pump - but did not state any of pulleys, tensioners, or what else falls into the complete timing belt service.
Local mechanic (former Acura dealer mechanic) who specifically works on Honda and Acuras in his own shop has quoted me $900 for everything (timing belt, water pump, tensioners, rollers, pulleys and all belts (serpentine, alternator belt, etc) ... he suggests doing the tune-up at the same time for additional price of I dunno maybe $100 - he did not specify... Anyhow, besides all this for $900 is tune-up recommended while doing the timing belt?
I am confident in this guy as I went there before, but want to be sure that I am given right information and to expect right amount of service for pretty much the same price.
Seeing prices of $700 here on the forums I wonder if that was only timing belt and water pump without other smaller things.
Thanks all!
Thanks all!
As far as I know, the job usually includes the timing belt, tensioner and water pump. The serpentine belt. alternator belt and the tune-up are separate, and I've personally never heard of them being companion services to the timing belt job.
"Recommended" only if your car is due for them or the belts look deteriorated on their own.
I believe plugs and timing belt are both done at the 105k interval so the recommendation is correct. The Honda dealers don't include the tensioner unless it is leaking, but it should be changed anyway since its all opened up. $899 seems a bit high, but us still cheaper than Acura.
Thanks for the replies to everyone so far: I am waiting on confirmation what he meant by all the belts - maybe he is throwing some stuff in to win business
(fingers crossed) - but it does sound too good to be true.
Tune-up I will likely do at the same time as I plan to keep this car for long after this service is done
(fingers crossed) - but it does sound too good to be true. Tune-up I will likely do at the same time as I plan to keep this car for long after this service is done
I have a similar question. My RL is currently at 102k miles so this has been on my mind. I'm a little down on my luck right now so I was thinking of just buying a timing belt water pump kit and spark plugs from autozone or O'Reilly and having a friend do the work at a discounted price. The kit includes water pump, timing belt, hydraulic timing belt actuator, camshaft belt tensioner, camshaft belt Idler. Is there anything I should know about me doing this on my own? Will I need anything else?
Ok, so I confirmed what he includes in his $900 quote (local mechanic) ...
Timing belt, Water pump, tensioners, pulleys, rollers and it does include serpentine belt. Tune-up however he told me would be additional about $200 with parts+labor, but then there is some kind of difference between early 2006 RL and late 2006 year version, because Acura supposedly changed something and when tune-up is done for late 2006 year version it costs $100 more.
Mine was sold in 2006 of May so I am sure I have "old" version RL - tune-up related condition.
So, so far it is looking at 1100-1200 with tune-up and timing belt with labor and all OEM parts.
Been covered in another thread.
https://acurazine.com/forums/2g-rl-2005-2012-76/all-who-spending-300-timing-belt-kits-888928/
) - but it looks like rollers are mentioned in the link that someone posted above. Tune-up wise, he did not really state there was different parts, but maybe something makes it harder to get to spark-plugs on the later 2006 model.
I will stop by the shop and ask the guy myself for more clarification.
Experience wise I do know he worked on Acura dealership for at least a few years as I believe he had bunch certifications and awards on his wall of the waiting room - but, beyond the point:
the way he gave me the quote, and how dealership gave me their quote it makes this mechanic GOLDEN SERVICE MECHANIC SHOP vs dealerships lame not interested in nothing whatsoever service... so yeah
I just got this done on my 09' at an Acura dealer in MN. Here's my breakdown
Timing Belt - 65
Coolant - 20
Labor - 530
Serpentine Belt - 50 (optional)
H20 Pump - 180 (optional, but no brainer)
Tire rotate - 25 (requested)
Coupon - (75)
Total - 868 (w/tax, etc.)
They mentioned the tensioner would be replaced if it was leaking, mine was not.
They also gave me a 2014 RLX to drive for 24hrs. I'll comment on that in a separate post.
Timing Belt - 65
Coolant - 20
Labor - 530
Coupon - (75)
I have heard of people ruining their engines because the belt broke, but never directly known anyone that had this happen. It is a real risk though. I've seen recommendations anywhere from 60k to 105k mi.
Personally, I have done this at 105k mi on my old 03 V6 accord and just did it at 101k on my RL. Excessively cold or warm climates are recommended to do this service earlier. Where I live, winter is -30C to -5C for a solid 3-4 months, but local mechanics have never suggested needing to go earlier than the normal interval. How warm is it in the part of Turkey you live in?
I know people have gone much longer than 100k miles without a problem. I don't see how it is worth that risk. Going beyond 60 or 75k is a risk I would personally take, unless there is some difference in european models that I am unaware of.
I'm no expert, but 105k mi seems to be the norm on the US side.
The obvious answer is that no one can predict when the belt will fail, and the same can be said for tesioners, water pumps, and gaskets.
So, either you conform and have an issue free vehicle or you chance it to save a few dollars and run the risk of ruining the engine.
Kinda like buying full coverage insurance vs liability.
Every 105k, so 210k.
Turk, members here have reported strong belts with little wear at 120k miles. One member has had his belt break, but it wasn't due to old age. More likely it was a defective belt. He replaced his whole engine himself. xplicitDX I think. He lives in Las Vegas.
While the temperature extremes can play a part in it, 99.9% of people are going to see that kind of climate, and I think cold will wreak more havoc than hot.
Here we go. DXplicitOne...
https://acurazine.com/forums/2g-rl-2005-2012-76/snapped-timing-belt-bent-valves-866518/
https://acurazine.com/forums/showthread.php?t=866518
honda recommends timing belt change at 100k miles
and at 60k miles if driven in mountains or extreme weather for kb1 acura rl
basic timing belt change in manual includes
timing belt , spark plugs , head valve inspect and adjust (very important)
water pump is no brainer
inspect the tensioner and replace if leaking is printed in manual
i did the tensioner and all rollers , replacing drive belt for ac power steering and alternator is easy so just inpect if cracks are visible replace
I got a quote from local acura dealer in Atlanta ga for $910 including taxes for everything listed here. Local honda dealer quoted me $825 but doesn't include tensioner. Only inspection. Can I expect better from another Acura dealer? Between these two I would go with Acura to get tensioner changed out plus they will provide me with a loaner. Thoughts?
As for other Acura dealers, they customarily charge more than Honda dealers for comparable services. That price sounds fair to me, and I wouldn't expect to beat it except maybe at an independent garage (which is often the best overall option anyway).
Called another local Acura dealer and got a higher quote. I'm going to see if the first dealer would make a deal at $900 even and throw in synthetic blend engine oil change at the same time.
Hey all - very valuable information given - thank you!
Since my last post, I have called two Acura Dealerships (besides Honda giving me 895$ quote for timing belt and water pump replacement)... and here is what I got:
Dealer #1 - 1385$ for timing belt and water pump replacement - nothing else included other than inspection
Dealer #2 - 1600$ for timing belt and water pump replacement and tune-up. Nothing else included.
I will be taking it to the certified Honda mechanic shop who is doing all for 1100$:
Timing belt, water pump, serpentine belt, alternator belt, spark-plugs replacement, tensioners, pulleys, rollers + all parts + all labor.
I tried to negotiate with the dealerships and ask to at least come down bit more to match closer to mechanic's estimate - no go...
I am in Chicagoland - so yeah - out of luck getting dealer to do it under $1000
Will do it probably in the next two weeks or so.
Thanks!
Glad to report that all is done and done with the sum up of $1150 total which included:
Timing belt service +
Water Pump
Timing Idler Pulley
Timing Tensioner Pulley
Timing Hydraulic Tensioner
Serpentine Belt
Engine Cooland
and
Engine Spark Plugs (Denso)
I know it may not be possible to see such different in driving but it may be that sixth sense that yees car drives smoother and better
Great service, great turn-around and happy with the price as well. Drew rocks!
Water Pump
Timing Idler Pulley
Serpentine Belt
Engine Cooland
and
