Slight Hesitation or Shudder On Light Acceleration
my 2012 RL with around 60k miles on it seems to have developed a bit of a mild shudder or hesitation only when you apply light throttle and under light load, like say when you just slightly put more pedal pressure to maintain cruising speed while climbing a slight hill. It seems to do it at pretty much any speed, around town or on the highway. If you apply more gas, or enough for the tranny to kick down a gear, it goes away and acceleration is smooth. It reminds me of how an old Toyota of mine would do the same when the plugs or wires or distributor cap+rotor were bad, except the Toyota would do it with all acceleration (light or heavy). Or another way to describe it is kind of like a much more mild version of "lugging" a motor in too high a gear for the load. No codes or check lights coming on. I had the dealer check the plugs and they are fine. It kind of seems like it's more noticeable when the car is cold and it's colder weather outside, but it's also still there on warm days and after the car is fully warmed up, just maybe not quite as noticeable.
The only thing that comes to mind is I have switched up gas station brands in the last month or so (new rewards program on the credit card LOL), but I'm still only ever using 91 octane (highest you can get around here).
From a search I did on here, some of the 3.7 V6 in the TLs seem to report this and it could be the torque converter? Would this maybe also be it with the RL? I've had the car 2 years, and from day one I always found the shifting wasn't as smooth as my previous 06 RL, which I just chalked up to being a different tranny (6sp instead of 5) and motor. I did have the tranny and all diff fluids changed when I bought it 2 years ago (about 30k miles put on since then).
Yes from what you are describing sounds like a torque converter to me. Mine was replaced under warranty at 71,000 miles before I bought it. I’m not sure what triggers it. I haven’t experienced any shudder with my car at all, but I know I’ve read posts where people have with their RL and it’s either been the torque converter or something with the drive shaft. I have over 150,000 now, and I do all fluids more than recommended as I’m paranoid about transmission/torque converter/differential failures. I do know that the original owner didn’t do a transmission/torque converter service before 60,000 miles on my car so maybe that’s why it failed. . . Idk.
JTS97Z28
May 5, 2015 11:07 PM
AtoZPC
Jan 2, 2014 11:43 PM
Acura604
Jan 11, 2011 07:08 PM
