Shaky mirror
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Went to the carwash a few weeks ago and noticed afterward that my driver's side mirror has the shakes. Lumps, bump, etc. cause the mirror to shake. So, it seems to have lost its stability. I tried pushing on the mirror and moving it around a bit. Doesn't seem to have helped much if at all.
So, I'm hoping you all have some suggested fixes, because buying a new left side mirror won't be cheap.
Thanks.
Thanks.
I was able to fix mine, there is this snap on cover at the bottom of the mirror which you will have to snap off it's place. There's a slot where you can insert what ever tool you will use to snap it off. Get a masking tape, tape off the part of the door that's near the work area to prevent some accidental scratches. Once the cover beneath the mirror is off, you will see screws that you will just then tighten. If it doesn't work then go to the dealership. I know you would rather have the dealership fix it specially if it's under the warranty, but the wait is what bothered me in the first place that's why i decided to give it a go myself.
And just wondering, why would you bring your car to a car wash. You can buy no rinse car wash products that you can use to wash your car yourself and prevent scratches and broken parts that a car wash can do to your car. Check out the Wash and Wax section and you will see which to buy and how to use them.
Good job on your part.
8th Gear
Thanks.
Thanks.
Thanks.
Thanks.
'05RL with delivery June, '05.
81,000+ miles.
Thanks for all the replies.....
I'll locate the little snap door and break out the screw driver to give it a try on my own first. It's apparent that something is loose, not really broken.
As for why I would go to a carwash....well...it's called lots of business travel to fill up my weeks and a long list of things to do each weekend. I wish I had the time and enegy to wash my own car, but I don't. Also, I've gone to this same carwash since the day then opened. Never had an issue. If anything goes wrong, the owner makes it right.
'05 RL 300K Miles
Same problem with mine. You just need a STAR KEY or a Hex KEY WRENCH to tighten a couple bolts, I can't remember which one I used. An Allan wrench won't work.
What tool to pop off cover?
What tool did either of you use to pop off the plastic cover? I have the same problem but I'm afraid of damaging the cover/door edge. Thanks.
First, be sure to put some masking tape exactly below the snap off under the mirror to be sure you won't scratch the door in case your screw driver slip. You can probably use those small screw drivers used by jewelers, they will fit in the small gap or just about anything you can fit in there. I used a very small allen wrench, as they are angled, it's easier to use leverage in snapping off that cover. Just remember to put some protection on the the door when you go this way.
....I used a very small allen wrench, as they are angled, it's easier to use leverage in snapping off that cover...
Originally Posted by fafpak
Worked like a charm. Was able to get the cover off. The two screws are bolted down pretty darn tight but there is still some play. I think the only solution is to find a couple of rubber/silicon type washers to eliminate the slack space. Thanks mr_allenp.
'05 RL delivery date June, 05
111,000+ miles.
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
