Servicing Air Filter
Old Apr 15, 2005 | 07:22 AM
fmcgirt's Avatar
fmcgirt
We have just been through a lot of dust and pollen and I would like to check my air filter. Anybody know how to get at it?
Frank
Old Apr 15, 2005 | 04:09 PM
kwaidoi's Avatar
7th Gear
Air Filter
It is very hard to take the filter out............the position and location of the air box makes it a pain in the rear!!!!!!!!!!!!!
Old Apr 15, 2005 | 09:28 PM
fmcgirt's Avatar
fmcgirt
I believe that but what I want to know is how do I go about it?? I don't want to remove shrouds, etc, that I don't need to...
Old Apr 19, 2005 | 02:16 AM
SodaLuvr's Avatar
Frank,
Do you mean the Engine Air Filter or in the In-Cabin Air Filter?
A single trip through excessive dust or pollen does not mean that you need to change your engine air filter, I normally inspect mine at every oil change to make sure that it is sealing properly. Remember, dirt (Silicon) is very abrasive to upper-end wear (Al, Cr, Cu, Fe) and can ruin your oil analysis results. Paper air filters typically last about 15-20K before they become loaded up with dirt.
Michael
Old Apr 19, 2005 | 07:22 AM
fmcgirt's Avatar
fmcgirt
Originally Posted by Michael Wan
Frank,
Michael
Michael,
I was not aware that the 2005 RL had a cabin air filter so I meant the engine air filter. I was just interested in how to check/replace the filter since there does not seem to be a service manual available for the RL. And if there is indeed a cabin filter, I haven't found it mentioned in the owners manual. If so, I would like to know how to get at it also.
Thanks for the response,
Frank
Old Apr 19, 2005 | 07:48 PM
Karl_in_Chicago's Avatar
Originally Posted by fmcgirt
Michael,
Frank
2005 RL Service Manual
Old Apr 19, 2005 | 07:58 PM
kwaidoi's Avatar
7th Gear
Air Filter - Service Manual
There is a service manual for the 2005 RL..........costs about $70.00 plus shipping.
Old Apr 19, 2005 | 08:06 PM
kwaidoi's Avatar
7th Gear
Air Filter Removal
To get at the air filter, you have to remove the small black covering that's just next to the air filter housing (about 2.5" long & 1.5" wide); its located toward the driver........this just snap right off. Once this is removed...............unscrew the four screws that holds the top section of the air box. Once you get the top of half of the air box off...........carefully move it up & out of the way in order to get at the filter.......re-install in reverse order.
Old Apr 20, 2005 | 07:38 AM
fmcgirt's Avatar
fmcgirt
Thanks very much for all the responses. And especially for the Service Manual URL. I have been checking Helm but not recently so I am glad to know about it.
Frank
bungln
Feb 20, 2019 08:47 PM
vpasla1
Sep 17, 2016 07:24 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
Aleax
Sep 9, 2015 08:04 PM
bymotion
Aug 31, 2015 05:00 PM
