RL Spoiler & Rust?
#41
2012 Cadillac CTS-V Coupe
Why is everyone so hesitant about drilling into the trunk? I had a spoiler on my '01 TL that was installed that way. In over 5 years of ownership, not one issue. No leaks and definitely no rust. That's even less of an issue with the RL since the trunk lid is made of aluminum.
#42
#43
AcurAdmirer
Originally Posted by jkuniverse
Couldn't agree more...
I'd drill my RL's trunk if I had the spoiler (which I may break down and buy soon).
#44
I think it's just the feeling of putting something permanent on there. Many people including me may want to sell the car later on and if the new buyer doesn't like the look of it with the deck lid, then I guess there's always the option of taking it off...
Plus, it's easier to just tape rather than measure and drill =P
#45
Asian07RL
I just called the dealer for the price of deck lid and installation.
Deck lid =$585.00
Installation=$100.00
I will order part on line for less than $300.00 and have the dealer install for $100.00. I will save $285.00.
Deck lid =$585.00
#46
AcurAdmirer
Deck lid =$585.00
Deck lid =$585.00
#47
Asian07RL
I have called to the service dept. and asked for installation only.
I will confirm with the dealer when my part arrives. (paid $297.00 Plus $3.75 handling free shipping)
I was thinking do it myself .(Hopefully, I don't screw up my trunk when I drill the mounting holes).
Note:
Someone here has mentioned the labor was 1/2 hour or $45.00
Note:
#48
I didn't want to drill holes becuase of the posibility of screwing something up, scratching, or not having the holes aligned right. Why do something the difficult way when there is an easier and much better way like using the 3M tape? I would be willing to bet anyone, and I think everyone who has used the the 3M tape can agree, that it would be easier to rip off a spoiler that was installed by drilling holoes and using the small bolts the dealership uses as compared to trying to remove a spoiler installed with my methed. The gap that is mentioned is there on everyones spoiler no matter how they installed it. The spoiler comes from the factory with double sided tape along the edge to prevent the spoiler from vibrating and rubing against the paint. This is needed because the entirity of the spoiler is not secured down except for the two mounting points of the bolts where the entire spoiler is secured when using the tape and there for no vibration. There is a rescessed area along the underside of the spoiler that you put the 3M tape. If everyone would remove the trunk lining and look where they would have to drill these holes I think everone would agree that it is not worth the risk and difficulty. I drilled through the trunk of my CL to mount the OEM spoiler on it with no problems, but that was a completely different type of spoiler. The RL's spoiler just lays flat on the trunk lid and does not weigh anything so bolts are not necessary.
Un-like what AsianTL expresses above, if you use the tape, you don't have to worry about screwing anything up and you save yourself a bit of cash to boot!
#49
backfire,
Did you install the struts that came with the kit?
I am affaid over the time, the OEM struts might get weak because of the weight of the deck lid and the trunk might come down by its own when open.
Thanks,
Thanks,
#51
Originally Posted by Mike_TX
Looks great, but there IS a gap at the front edge of the spoiler on the ends (see pic #1521). I assume (?) that's because of the thickness of the two-sided tape.
Whether that bothers someone or not is up to them, but it sure looks like you'd snag it when drying or polishing your car. For me, that's not enough to be a deal-killer, but I might opt to go ahead and drill it if it were mine.
As I said though, it looks good, and the spoiler gives the trunk just enough definition to make it look "finished".
#52
5Zigen Acura RL
Hey guys,
New to these forums, just purchased a 2005 RL a couple weeks ago. I found this thread on the spoiler just before I was about to shell out $550 w/tax to my dealership to put the spoiler on. I ordered it online, arrived yesterday, used the double sticky tape method and it's on there tight and flush and looks GREAT! $307 total including the tape. Thanks for the advice!
Jason
Jason
#53
OK OK OK you have convinced me that I can do this myself. This may be my next mod if I don't decide on the Mugen first!
BTW, welcome to Acurazine, Jaysmith, post and enjoy!
#54
Asian07RL
[QUOTE=AsianTL]I just called the dealer for the price of deck lid and installation.
Deck lid =$585.00
I will order part on line for less than $300.00 and have the dealer install for $100.00. I will save $285.00.[/QUOTE
I did order the deck lid spoiler ($301) from Acurahondaworld and Wood steering wheel, Wood knob ($470.00) from Kendall acura honda.
I will have dealer install the steering wheel only and do the rest myself.
Deck lid =$585.00
#55
AsianTL, I hate to cut you off at the pass, but the steering wheel is even easier to install than the spoiler! Took me about 10 minutes and not a single second of frustration. Easier than the wood shift knob IMHO! Just spend the $15 for a steering wheel puller and presto, your finished with the install quicker than it would probably take you to drive to the dealership!
#58
It's made by 3M
Really expensive
Has a red plastic backing that you peal off
Here is a link with a little more info on this tape. Hope this ends all the concernes that have been voiced over the strength and durability of this tape.
http://tapeinfo.com/TapeInfo/3M/3MVHB.aspx
Really expensive
#59
Asian07RL
I used up 2 rolls of 3M interior/exterior tape which I picked up at Home depot.
It Held up really good and no gap.
Just got the wood shift knob done by myself and wood steering wheel installed by dealer for $113.25 tax included. They look really good and I would recommend them to anyone.
A-spec under body kit just arrived home and will be installed by dealer the end the month for $394.00 before tax.
#60
TRY THIS I THINK IT WILL WORK I BOUGHT A LARGER ROLL AND I THOUGHT IT WAS AT HOME DEPOT http://www.autozone.com/servlet/UiBr...243609NA%24MMM
