RL gone crazy.
Old Aug 20, 2010 | 10:53 PM
tomb543's Avatar
RL gone crazy.
So about a month and a half ago i went to reverse out of my driveway and when i put the car in to gear it just went ape shit, the Emissions light came on, check transmission on the mid, AFS came on, blah. I turned my car off and back on then no lights except check emmisions came back. I disconnected the battery to see if i confused a sensor or something, and vwala! all was good, or so i thought. The code did store in the computer, But all was good untill today. I started the car, then boom. AFS,Emmisions,Transmission, No Keyless entry. I just want to now if anyone else had this problem happen to them. im not really concerned since the car is running well i just wanted to get some insight on what the problem might be before i go to the dealer and get anal probed.
Old Aug 20, 2010 | 11:39 PM
csmeance's Avatar
go to autozone and get the battery checked out. Many issues like this are caused by a dying battery, and with the electronics laden RL, it wouldn't surprise me that if it was just your battery not giving the correct voltage at startup and spiking a module or two with electric!
Old Aug 21, 2010 | 06:09 AM
Pint's Avatar
Most likely battery, as mentioned above. The same issue is common on BMW's e65. A bit dried battery triggers errors on dash screens.
Old Aug 21, 2010 | 12:56 PM
tomb543's Avatar
Yeah well i took it to autozone to have the codes checked out, but there are no codes. he hooked it up and said man you have nothing showing up your good, so i think it is the battery. Thanks guys
Old Aug 21, 2010 | 02:40 PM
lvnLegend's Avatar
This has happened to me. It registered a code "p1717. I noticed that the car was shifting and driving a slightly differently.I came to realize it was my gas cap not being screwed on tightly.Once I squared that away and restarted the car it all went away.This may be what you are experiencing. You can start with this and see if it works.
mike from annapolis
May 7, 2017 08:21 PM
cm561
Jan 27, 2016 10:17 PM
Medinak12
Sep 23, 2015 07:11 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
VeeralS05
Dating & Relationships
58
Aug 26, 2005 01:08 AM
