replacement shocks any recomendations??
Old May 8, 2014 | 10:42 PM
dre707's Avatar
I've been looking to buy some replacement shocks for my 2006 Acura rl and there aren't many out there that they make for our Acura rl I ran into these and was gonna get them but wanted to ask you guys if these are any good or any recommendations you guys might have
http://www.jcwhitney.com/kyb-gr-2/ex...id=d7y2006g2j1
Old May 9, 2014 | 03:14 PM
badjuju98's Avatar
Those are what I am using. Stock shocks died on me. Probably 20k and no problems. Terrible time replacing them.
Old May 9, 2014 | 04:26 PM
charlesm23's Avatar
Are these for just the front struts?
I've been trying to find the complete KYB set for my 05 RL. Tire Rack only lists the front and said they don't have the rear struts. So I've called my locally Acura dealer and they priced them at $202 for each rear strut with is twice $$ as the KYB.
Old May 9, 2014 | 08:20 PM
oo7spy's Avatar
The KYB reviews are pretty terrible for heavy cars.
Old May 10, 2014 | 12:56 PM
pcloadletter's Avatar
That's odd, as the RL does not have rear struts.
Old May 11, 2014 | 07:55 AM
Frenetic's Avatar
My struts/shocks are toast too.
It actually happened rather suddenly during my last tire replacement, after they jacked the car. The ride got a lot rougher and noisier during suspension movement. Nothing loud, but a low-pitch, subtle "thunk" upon sudden suspension movement. It's almost unnoticeable, and I got use to it, but it's definitely not normal.
The advisor mentioned there is actually a service bulletin about our struts/shocks, that upon lifting, something can fail and make the ride "4x4ish" and rougher for lack of a better term.
I need to get mine replaced as well, although the oem part is rather expensive. The advisor never mentioned the rear shocks, just the front, but it's noisy back there as well.
Anyone replace all four and would you mind sharing how much for parts and labor? Thanks.
Old May 12, 2014 | 08:51 PM
The rear seats, deck and c-pillar air bag cover panels have to come out to access the upper rear shock bolts. The manual states hit the air bag label with a hammer to break the fastener, replace. It took me over a half hour to remove the rear interior when I replaced the sub woofer. The front springs need to be re-assembled within a few degrees, otherwise the fork will not align with the lower a-arm. This job is time consuming and likely more costly than the average car.
Old May 13, 2014 | 01:08 PM
oo7spy's Avatar
Hitting the c-pillar with a mallet deterred me from that step when I put in my subs.
Old May 13, 2014 | 08:45 PM
I was able pull the c pillar panel down and inward to remove it without damaging any clips contrary to the manual procedure. I wonder how much time Acura allocates for the rear shock replacement and how many shortcuts an independent shop would take.
Old May 14, 2014 | 03:15 AM
dre707's Avatar
So it seems like replacing shocks on the rl is a pain the ass am I right? Also is it difficult to install some subwoofers I have a sound system in my previous car and I wanted to pass it over to my rl I have 2 amps one for highs and one for the subwoofer but I think I'm just gonna try to put in the subs how hard is it or should I just take it to a stereo shop??
Old May 14, 2014 | 11:08 AM
oo7spy's Avatar
Not very hard. https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/diy-amp-wire-backseat-removal-813630/
You don't have to drill the firewall either. Unbeknownst to me, there is a hole under the dead pedal that you can use.
Old Jun 2, 2014 | 11:24 AM
dre707's Avatar
I found some guy selling some oem shocks that came off a 2009 Acura rl with about 60k what route would you go? Used oem or some new kyb shocks? I can get all 4 used for $125 or $75 each new shock????
Old Jun 2, 2014 | 09:35 PM
Iakonafuji's Avatar
I'd go with the guy selling the OEM shocks Haha..but tbh, realistically it would be feasible to run these at an affordable price without breaking the bank, and in the meantime save up for a more expensive ($1-2k) set of coilovers.
Old Jun 5, 2014 | 03:50 AM
dre707's Avatar
Haha of course since your the one selling them to me. no I don't think I'd be interested in coilovers too much for me just for some shocks I will stick with regular height for me maybe get some 20" rims instead but I think I will just end up buying the front 2 kyb shocks
Old Jun 5, 2014 | 08:10 AM
Iakonafuji's Avatar
You also just told this to the guy with a set of 20" SSR GT3's for sale too y'know! LOL
Old Jun 5, 2014 | 11:12 AM
oo7spy's Avatar
I wouldn't be surprised if the 60k stock shocks are the same quality as new KYBs.
Old Jun 5, 2014 | 01:56 PM
projektvertx's Avatar
Wouldn't surprise me. While KYB are technically the OEM supplier for the struts (at least they were for the 1G RL and my Camry), they don't ride the same, plain and simple. When I replaced the struts on my 1G RL with KYB Excel G's, the ride was a little stiffer overall. I'd spend the extra money for OE struts and shocks, honestly. But it's your money
Old Jun 12, 2014 | 04:21 PM
tlmaster1's Avatar
get the A-spec Suspension OEM from any Acura Dealer for $500 for all 4. shocks and springs included.
Old Jun 14, 2014 | 09:34 PM
TonyCD's Avatar
Thanks.
The same thing happened to me. One of the front struts got hung up somehow in a stuck position when the car was lowered off a lift. The fix was simply to lift it again and dislodge it. I don't think it's the same problem you have, though.
I knew a guy who was exceptionally knowledgeable who told me OEM was the ideal way to go on our RLs, because there's some sort of sensor in there that contributes inputs to the SH-AWD and/or the stability control. Can't confirm that, but he generally knew his stuff.
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
niray9
Dec 8, 2015 07:34 PM
pizokk1
Sep 17, 2015 09:29 AM
Billu99tl
Sep 13, 2015 11:30 AM
