Removing heavy swirls from paint
I just can't live with the heavy swirls all over my 2006 RL with Nighthawk Black Pearl paint so I purchased a Porter Cable 7424XP 6" variable speed orbital buffing machine and Wolfgang Total Swirl Remover. i should receive it in a couple of days. does anyone have any experience using this tool that would have some pointers that might help me. I tried numerous products to remove these swirls by hand and had no success.
There is a whole sub-forum dedicated to this stuff. Good luck. https://acurazine.com/forums/wash-wax-23/
for pics.
for pics.
It's all about the choice of pad and compound cut. The very light cut polishing pads (typically these are "white") and Meguiar's 205 compound usually will take care of swirls pretty nicely. A lot of people also don't apply enough pressure with their polisher and "rush it" and don't spend enough time working a panel/area with the machine.
I also got a PC to remove swirls on my NBP RL too. The RL's paint is rather soft, so I used a medium cutting pad, and polish for a first go around. Then finished it up with a light cutting pad with a finishing polish to get rid of the swirls the medium compound and pad caused. But for deep scratches, I would use a medium cutting pad with a heavy cutting polish.
Use an orange pad with a good cutting polish. Then follow with white pad and a finer polish. Then wax. I'd suggest claying the car first. I use menzerna products, but others will work too. It's back breaking work and takes sometime so have patience. 5- 8 hours to do it right.
I concur, clay bar the car first, then polish. Menzerna products are awesome too, that's what I used.
I basically used this polish:
http://www.detailedimage.com/Menzern...P649/16-oz-S1/
as the first step with this pad:
http://www.detailedimage.com/Lake-Co...P58/4-inch-S3/
and finished it up with this polish:
http://www.detailedimage.com/Menzern...P228/16-oz-S1/
with this pad:
http://www.detailedimage.com/Lake-Co...Pad-P61/65-S1/
only use this one if you have deep scratches:
http://www.detailedimage.com/Menzern...P124/16-oz-S2/
Remember to also purchase multiple pads as they'll get clogged with product. It took me about 32 hours to finish my whole car...as a one man job. A little long? Yes, but at least I know that I've done a good job. Just be prepared for a major time commitment.
with this pad:
Yep definitely clay first. If you can't "feel" the swirls/scratches in the paint surface with the edge of your fingernail, I've found a white pad with the 205 polish and the porter cable set at 4.5-5 speed and working the area over slowly is usually all you need. Always start with the least aggressive pad and compound, then check your results, then step up to more aggressive only if you have to. The first few times I did various cars I was surprised at the pressure you need to apply - the pads will get pretty warm in the center in fact!
^what brand are they?
different brands have different meanings.
generally speaking
orange - mild cutting
white - finishing
black - very soft and used to apply sealant.
you want to start off with the LEAST aggressive pad when trying to get swirls out. if cannot remove, step up to a more aggressive pad.
with that being said; you DONT WANT an aggressive pad applying sealant. you'll scratch and mar up your paint!!
some dont even use the machine for applying sealant, as you can mess up your work. apply by hand!
generally speaking
white - finishing
Thanks very much. So far all I have is an orange and a black coming. So do I need to buy another pad for applying the Finishing glaze 3.0. If so I would go over to Home Depot to purchase. I will apply the sealant by hand only as per your expert information.
^its experimentation, sir.
if you find your orange pad is cutting to much!! go to a lower pad.
if you find your white pad not effective enough, step up to a more aggressive pad.
each car is different and will present different hurdles.
Dont overthink!!
if you watched the videos on youtube, you got it!!!!!
I will present you with one last piece of advice. have multiple of each pad.
the pad is a sponge and WILL get over saturated with product. having two or three of the same pad makes it easy to switch out and continue to work.
Be sure to wash all your pads when you're done
Dont overthink!!
thats what the machine is for!!! paint!
if you watched the youtube videos, it will show you the process on how to: prep your pad, apply it to the car at a slow speed to spread product, and then bumping the speed up to actually correcting the paint defects.
please dont over think this!!
the hardest part is the physical part. after a hard day's work, Im super sore from squating, bending, moving, etc.
I did all of the prep as per the video by Mike Phillips that came with the machine and also watched all of the Utube videos. I did the trunk this morning which had the worst swirls and only needed 4 section passes to get amazing results. I did notice that the machine really vibrates when the speed setting is on 6 but that takes getting used to. I am hooked. Thanks again to everyone for your expert advice.
I am keeping it in the garage until tonight when I will apply the sealant by hand so as not to mess up my work. Took a total of about 5 hours to get to this point. Should be OK until then. Not driving at all today.
Another GREAT product for paint is from a company called 3d products / HD car care. Youtube "HD uno".
No hazing and phenominal results. I just used it on my foggy RL headlights and they look brand new.
They had a deal when I bought my stuff. I got a DA polisher, detailing products, carrying cas all for $99.
I have LLumar 30%.
The film brand should always be the first choice. Even with a skilled professional installation, a low quality film will break down over a short period of time. For over 35 years, LLumar has been recognized as the premier film in the industry. LLumar's lifetime guarantee towers over all other brands supposed "lifetime" warranties. LLumar is the only proven film to keep its color. Bubbling, peeling, demetalizing, delaminating, fading, and color change are what LLumar promises you'll never see.
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
merc009
Oct 3, 2015 12:59 AM
HOWELLiNC
Sep 18, 2015 11:12 PM
detailersdomain
Wash & Wax
Sep 3, 2015 10:56 PM
