Regarding First Service
Old Jul 15, 2007 | 01:48 PM
backfire's Avatar
I am curious what you guys did when the service minder says service soon, A1, yet 15% of oil life left. I have just over 5000 miles and that is where I would usually service oil. Do you wait till is says change or do you service oil now??? Thanks
Old Jul 15, 2007 | 02:41 PM
jfprl's Avatar
I servic mine shortly after the 15% warning comes up. I do not like looking at the orange reminder in the dash.
Old Jul 15, 2007 | 06:09 PM
neuronbob's Avatar
I do the same, for the same reason--every time you try to change to a different display in the MID after a certain interval (30 seconds?), you have to get past the reminder about the oil change. VERY irritating, which is the intent of the message.
Old Jul 15, 2007 | 09:28 PM
backfire's Avatar
Thanks Thats me too I just thought maybe I was missing something. First Time I let the dealer do since I have a couple issues.
Old Jul 15, 2007 | 10:33 PM
PortlandRL's Avatar
Ours just lit up for A1 service at 15% oil life last week at 5200 miles. It's going in on Thursday.
Old Jul 16, 2007 | 01:49 AM
Strategr's Avatar
I had 50% oil life left at about 3,000 miles and had it changed since I was at the dealer because the air vents smelled musty at times, although they couldn't smell it. (Like a doctors office, as soon as you go, everything is better.) They put some ozium in the vents and intake and the smell is competely gone.
I also needed the coolant topped off.. at 5% humidity and 115 degrees in Las Vegas, it can evaporate a bit quicker than normal.
Speaking of coolant, what coolant can you uses to top off? I am a bit confused from reading the manual. Doesn't seem to be normal and extended life version. I can't believe it is a totally special coolant, althought the Acura service center thought it was- but I think the guy wasn't very knowledgable being only the service writer vs. a tech.
Old Jul 16, 2007 | 05:52 PM
backfire's Avatar
ALL hondas are special coolant. If you use any others you will rot the system out( I have been told)
Old Jul 16, 2007 | 07:59 PM
Chas2's Avatar
I believe the Honda Type 2 Coolant is the blue 5 year stuff. From the 2006 Manual P. 366. I have the same stuff running in my 1995 Legend after they replaced the head gasket.
Always use Honda Long-life Antifreeze/
Coolant Type 2. This coolant
is pre-mixed with 50 percent
antifreeze and 50 percent water.
Never add straight antifreeze or
plain water.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
