Random Brake Caliper request
Old Jun 11, 2009 | 02:03 PM
endlesswinterco's Avatar
Always Winter!
RL guys,
sorry for the random question, but im trying to source brackets for the RL caliper to my tsx. I was wondering if you guys could measure on your calipers the distance from hole to hole where the bolts screw onto the hub/bracket.
Thank you so much for your time and effort.
Old Jun 11, 2009 | 02:13 PM
KB1Spec's Avatar
Stock caliper? or Aftermarket?
Old Jun 11, 2009 | 02:14 PM
Always Winter!
sorry the Stock 4 piston Brembo Caliper.
heres a picture of what i need, the red mark distance.
Old Jun 11, 2009 | 02:27 PM
KB1Spec's Avatar
As far as I remember, IT MIGHT fit. I try to measure it with my old Brembo BBK from my TL/TSX and the hole seem to be similar. Only thing you need to do is probably do a custom bracket.
Old Jun 11, 2009 | 02:34 PM
Chas2's Avatar
And of course remember that the RL calipers are not made by Brembo, but Nissin.
Old Jun 11, 2009 | 03:06 PM
Always Winter!
yea, i have a brembo bracket that i think will work already, but need to know for sure the distance between the holes, before i buy the calipers. then rotors will be on the list. anyone have this measurement?
Old Jun 11, 2009 | 03:33 PM
Rhlieu's Avatar
Got any more info on this Chas? I always though they where made by brembo and rebranded to make it look Acura OEM stock?
Old Jun 11, 2009 | 04:56 PM
Ballinger's Avatar
The RL car-show KB-1 had Brembo brakes, and the TL's have a "brembo-licensed" brake bearing the Brembo logo. The KB-1 RL's we all drive have magnesium-bodied, 4-pot Advics brakes.
Great photos, HERE.
Old Jun 11, 2009 | 05:20 PM
Always Winter!
anyone have the measurment i need?
Old Jun 11, 2009 | 06:04 PM
neuronbob's Avatar
Hey guys, anyone have a service manual to help this guy out? The answer should be in there. If I still had my RL, I'd go out and measure.
Old Jun 11, 2009 | 08:40 PM
jfarabaugh's Avatar
I got the service manual....you really think it will be in there?
Old Jun 11, 2009 | 08:48 PM
jfarabaugh's Avatar
Just went through the entire brake section....I can tell you how to remove and install them but not the measurements.
Old Jun 11, 2009 | 08:55 PM
jfarabaugh's Avatar
just measured with the wheel on....got 5.25" maybe off by 1/16th"
Old Jun 11, 2009 | 09:31 PM
Chas2's Avatar
I really don't know what I am supposed to be measuring. There are four obvious bolts that I could not really measure without removing the wheel, which I cannot do right now.
The inner pair looks to be between 5.25 and 5.5 The outer pair is close to 9.5
This is a picture I took last year, to show you the two pairs of bolts, but I really need to take the wheels off to get a good measurement. Maybe on the weekend
Old Jun 12, 2009 | 12:10 PM
Always Winter!
thanks for your help guys, but these are the two bolt gap that i need measure.
these are the bolts that hold the caliper to the hub. they are running the direction of the arrows, that is the gap that i need measured. thanks again.
Old Jun 15, 2009 | 06:47 PM
Always Winter!
anyone????
Old Jun 15, 2009 | 08:57 PM
Chas2's Avatar
I won't be able to do anything until Sunday maybe.
Old Jun 18, 2009 | 06:23 PM
neuronbob's Avatar
Surprising. Thanks for trying, though.
Old Jun 18, 2009 | 09:13 PM
woodek's Avatar
I can see that the bolts are 14 x 1.5 mm (78 N-m), but thats about it in the manual.
Old Jun 19, 2009 | 09:39 AM
foam4me's Avatar
Have you tried going to the Parts Counter at a dealer to get a sample and then measure with a steel rule?
Old Jun 20, 2009 | 06:00 AM
neuronbob's Avatar
Given how uncommon the 2G RL is, most dealers won't have a sample on hand and would have to order it. Worth a call, though, maybe the OP has a high-volume dealer nearby.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
