pulstar plugs
some dude in the 3G section is using them, its just snake oil. Your best bet if you need to change plugs is do this:
1. Seafoam your RL with the OLD plugs in
2. Change out your plugs with NGK one's, they work well, last long and are great.
3. change/clean out the engine air-filter since sparks and filter are usually at 30K intervals.
so i've been reading around, and the plugs just seem to be a big gimmick. Apparently the tips are very brittle. This one guy on an EVO forum has pics of his plugs and damaged engine parts. Clearly i'm going to stay away for now.
I actually have a set in mine (compd) along with a set in one of my other cars. There is an improvement in throttle response and perhaps a small HP improvement but what I did notice is a 1.5 mpg increase in the RL. This goes along with what some others I know are getting on their cars. Some cars respond better vs others.
Replaced fairly new plugs and same driving style. ECU reset. Again, keep in mind that I did not pay a penny for the 14 plugs (8+6)
Early versions were prone to cracking. The new ones are suppose to be stronger, I have not had any issues. The tip is still the standard plug tip though, no iridium or platinum so keep that in mind. They do come with a 30 day guarantee, at least through Kragen Auto. Not sure of other places.
Cheers
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
