Pop Up Hood PUH light
My Honda KB1 spontaneously decided to turn on the PUH light. I've checked everything but can't find a solution. The OBD reader also does not turn off the error message. As far as I know, I didn't hit anything. Anyone have an idea?
Oh Gawd, I'm familiar with this.
Has someone reversed into your front bumper? If they've dented the flimsy crash bar & the three sensors aren't aligned within ten degrees of each other (IIRC) then you'll need a crowbar & hammer...
I've had that...
Got it all fixed and then later a pheasant committed suicide & blew up my bonnet.
I've had that...
zeta (09-04-2024)
Yeah, I've looked 'high & low' on the OEM vendor parts diagrams to find & understand anything related to the PUH system and came up blank.
I'm totally over looking something or it falls under another descriptor?
zeta (09-04-2024)
From sea to shining sea...
There was a UK Leg End forum, but that went the way of ToV a looong time ago.
How's the US DAF forum getting along..?
Seriously, it is a bit of a problem - a lot of the electrical stuff in 'handed' for RHD cars and there are some spec differences, also between UK & JP. Obviously, NL is LHD.
The PUH stuff is buried inside the SRS module, which makes replacement/repair a bit problematical. And it's a swine to get to.
Bull's best bet is to talk nicely to his local Honda dealer & see if they'll pull the error code first, for not too many Euros. Or pull the bumper cover (watch the temperature sensor wire - it's bloody short!) and get out a straight edge.
