Picture of Drive Shaft Center Bearing
This is what the repair shop gave me back to me when I paid them $600 to replace the center drive shaft bearing, and u-joints, and rebalance the drive shaft. It didn't fix the whining problem though...so either the bearing they put on was also shit, the bearing isn't the problem, or they lied to me. The bearing looks suspiciously small but they have always been honest with me in the past so I have no reason to believe they lied to me. So if you were wondering what was (according to honda) causing the whining problem with the drive shafts here it is
There are no serviceable parts on the prop shaft in the honda catalog. That's not to say a driveshaft shop couldn't simply press in a new bearing but if swapping out the center bearing was the fix, honda would have done it years ago when they were sending out new carbon props every time someone complained of this noise. Hav u crawled up underneath to see what your 'new' shaft looks like?
I thought your noise was the impending doom of your diff.
HEAVY_RL (04-24-2013)
Yes first the differential went bad and was causing a high pitched whine/grinding noise. I had the differential replaced with a used one I picked up cheap, then I noticed I now had the propeller shaft whine that occurs between 32-35 mph and the driveshaft is cold.
Yes the noise occurs when it is cold and does not occur when the temperature reaches above a certain threshold. Regardless something is still wrong with the drive shaft.
Yes they got the new bearing from "Precision Bearing Company" in Omaha, NE which is where I am located. I am going to look under it soon to see what it looks like, I know I won't be able to see the bearing anyway so I wasn't in any rush. I believe the reason Acura didn't have new bearings available is because the task is fairly complicated and the drive shaft has to be rebalanced among other things. Things I don't think the typical dealership shop is capable of, but I wouldn't no for sure.
I had the bearing on my driveshaft go a few thousand miles after the powertrain warranty expired. I had complained about it prior to the expiration, and ultimately Acura covered half of the cost of the repair.
I have the whine and it's getting louder, I guess I need to get this diagnosed by the dealer when it goes in for a leaky power steering pump. If something is worn then my extended warranty should cover it. If the bearing does nor cause the whine, what does?
justin7779
12-25-2015 10:33 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
