Nothing working except inside light and horn
How is everyone hope you are all doing well.
Major problem today I'm hoping you guys know what it can be. I've searched but this seems like a weird problem.
This morning got into the car and drove as usual. Car was then parked all day, until i went back and nothing. I mean nothing. I put my hand on the handle, nothing. I press unlock, nothing. I tried the other fob, same thing. I used the key to get in, and opened the hood, the batter tests at 12.7. Inside, can't put it in neutral, can't turn the ignition to I nor II, headlights don't work, nothing. Only the radio theft red light was flashing. Inner lights when set on 'door' don't work. If i put them on, they do. The horn work.
From the fob, if i press the red panic button, the horn sounds.
I removed the negative cable from the battery for a few minutes, and reconnected it. Nothing. It's a scary scene.
Anyone has any ideas?
Thank you.
Thank you.
The battery's 6-8 months old. it tests 12.7 now. I'll try it. But the horn is strong. The lights inside the car are strong. But they don't go on when the door is open, but do go on if i press 'lights on'. Which tells me fuse or module no?
I checked the 120 and 50 fuses, they r fine. The 1 & 2 below steering wheel are fine. So maybe module?
Since a couple of weeks, when i hook up my iphone, it keeps beeping as if its charging not charging charging not charging... several times. Also, the climate control and clock dash went black twice recently and a little tap on its head brought it back.
Plus the passenger side pillar leaked loads from the rain last week.
Even if module i got no clue which.
Where's each one of these located, how to test them and what do they cost? I'm searching, not easy to find.
Quite embarrassing actually.
i had pressed the panic button earlier today to test if it's working and it did and I think pressing unlock stopped it. Now, I inserted the key, the car starts but immediately sounds the horn continuously and nothing's stopping it. Woke up the neighborhood I'm sure.
1st thank you so much. Second, how do I stop it from honking? It thinks I'm stealing it.
On ignition I, i pressed the radio on, and it asked for the code. i entered it, the radio works. Iggnition II triggers the alarm.
I tried holding the key in open position on the door for few seconds. The other doors do not unlock, and the alarm still goes off.
I don't know about '09s but there is a cap you can remove off the ignition and it lets you put in the physical key on the '05-'08.
Is your immobilizer light flashing on the dash? Should be a green key symbol.
As for using the physical key, it should be the same as the earlier models. Remove cap from ignition, there will be a slot on the bottom of the cap to slide the key in popping the cap off so you have access to the ignition slot.
Guess I misread, you did figure out how to use the actual key to start the car?
PS. If it happens to be the ECU (hopefully not), here you go..
http://m.ebay.com/itm/142109807385?_mwBanner=1
Yes i managed to turn it on, but, like i said above, when i turn the ignition to II the alarm goes off. i tried several things mentioned above.
I read in another thread the door handle could be blowing fuse 7, etc. but i have no clue how to proceed or what could be the reason.
Fuse no 7. Replaced it, horn went off 3 times then fuse blew.
Then te door handle shorted out. Is it driver only or could be pass side?
How do you disconnect the handle? Any fuse or wire?
Help
Help
Okey. So...
I removed the horn's fuse and tested a few things.
Now, neither here nor online it ever mentioned what I'm about to type. to deactivate the alarm, it say you have to put the key in the door and turn. Some even say few seconds etc. But, i kept going back and forth, open ignition, shut, go to door, turn, back to ignition, once on II, alarm goes off.
So, I basically went in and got my wife's key, started the car with one key, alarm on, then put the second key in the door and turned. it shut the fuck up!
Now, i lock the car, go back in normally, and it simply starts with the key. Phew.
So, status now, in case anyone would like to help me, is that i got Fuse #7 blown and keeps blowing. Door locks, cabin light when 'Door' option is chosen and Navigation do not work.
I need to stop what's blowing it, and this thread https://acurazine.com/forums/second-...doesnt-878925/ says that its the handles leaking water and that there was a service bulletin on them.
Does that mean Acura will pay for this defect? And is there a fuse or some wire I can unplug so as I can put a Fuse 7 back in and get other functions back?
My passenger's has always been on and off. Often only locking not opening etc or the opposite. Sometimes nothing at all.
The driver's always works without fail, but it's small casing, the cover that surrounds the keyhole, is loose. It clips on but can be easily taken off.
See my dilemma? I suppose I'm going to remove both and see which stops the fuse from blowing.
Can't these handles be fixed and then sealed with a clear silicone?
I think this was a problem before I bought the car. The clue is the liner in the trunk on the left side that was always taken out, and i wondered on here why last year.
The fuel cap button doesn't work, so i had to pull the wire from the trunk, exactly where that liner was pulled when i bought it.
So, dealer fixed those handles somehow, and sold me the car.
The cap can probably be siliconed back on, depending on the extent of the damage to the clip. I would use a small dab of 3M trim glue. Just an FYI, it does come pre-painted if you were to buy a replacement. Is it too late to go back to the dealer on the handles? They might be able to warranty the replacement part?
The cap and clip are fine. Its the seal that's the problem. We're not supposed to be able to pull them out and back on so easily i think. The service bulletin on them says its the seal too. leaks water then havoc.
I bought my car as the second owner. it's out of warranty time. I dunno. i'll try.
Gonna work on disconnecting them soon. Hope it's as easy as it seems.
If the dealer replaced the handles when you bought it(?), my understanding is OE replacement parts have some sort of limited warranty (usually a year or less). I doubt it's worth pursuing at this point but just a thought. As far as the separate cap issue is concerned when mine become loose I just replaced the cap itself and that fixed my issue. I don't remember getting the seal with the replacement cap though. My clip appeared fine from the outside when it started becoming loose at the time
I removed those 3 screws, and pulled the panel clips all around, but its as if there's something stuck bang in the center of the panel. I didn't wanna break it. so, I re-assembled it. Grrr
No I removed that too. That, door handle top screw and inside the door latch. As per te video above. Couldn't find others in case 09 was different.
it may be a clip too hard but it's too stuck in there, dead in center of the whole pannel. don't wanna risk bending the panel or breaking it.
It turns out there's a fourth screw! Damn you Scottsan!
It seems it's 4 screws on the 09-12, and 3 screws on the 05-08. The 4th was in the armrest, inside that pit that has a rubber floor, well you need a very sharp and pointed tool and pick on it to lift up, then pull it. It's indeed dead in the center of the panel.
So the whole operation took 10 minutes. Disconnected the passenger handle, and Fuse #7 no longer blew! Now all works again, except passenger handle doesn't lock/unlock by touch, which was intermittent anyways, and never used.
Thank you for those who helped out.
I'll be back to post whatever new thing I learn that I know from my posting on here would be useful. As I always did.
Thank you.
It seems it's 4 screws on the 09-12, and 3 screws on the 05-08. The 4th was in the armrest, inside that pit that has a rubber floor, well you need a very sharp and pointed tool and pick on it to lift up, then pull it. It's indeed dead in the center of the panel.So the whole operation took 10 minutes. Disconnected the passenger handle, and Fuse #7 no longer blew! Now all works again, except passenger handle doesn't lock/unlock by touch, which was intermittent anyways, and never used.
Thank you.
Thank you.
Thank you.
If you see second 19 in the video, the 08 armrest has no dents or pits in in.
The 09's door is quite different. The armrest has a pit that fits 4 fingers, u can use it to pull the door to close it, also with its rubber and slightly studded flooring, seems like a place you can keep coins, or other little things where the leather walls and rubber flooring won't make a rattling noise... etc.
So in the 09, below that rubber, there's a 4th screw, the other 3 being exactly where the video above shows.
White plug in vicinity of handle or connection to inside handle?
Hi guys...
I have door panels off and looking to disconnect handles/ sensors... What do I unplug? The white plug in vicinity of outdoor handle or plugs that run into the indoor handle?
Thanks much 🙏
Thanks much 🙏
Once your door panel is off, the plug going into the outdoor handle should be pretty straight forward.
Dunno why you got both door panels off tho, the problem usually is on one side. The side that's been working on and off (outdoor door handle).
I have no power to anything #7 fuse powers, blew after replacing.. Pulled drivers door panel and unhooked white plug ( only one easy to see in the area of handle) threw new fuse in and it blew.. I pulled passenger door panel and unplugged same white plug.. Threw in another fuse and it blew instantly as well. So here I sit , on my thumb, at least comfortable with removing these door panels now 🙍
Btw the drivers handle was a bit finnicky before this happened.. I should reiterate I didn't completely remove door panels but could access the main visible few plugs..
Am I just being lazy and have to take the door panels completely off to get the right plug disconnected? I unscrewed the 3 screws -2005 RL- and popped off all clips. ..
Wow.. Well, the extent of my knowledge is the door handle shorts, fuse 7 blows. So, if you are certain you have unplugged both door handles, and it still blows, well, that is outside of my small sphere of expertise.
Thanks for the help.. I knew I was off here because this problem is just like mine. I'm off to do the work, and I see what I did.
I unplugged the actuator plug shown in some pics in this thread ----link below----(larger white plug super easy to see in vicinity of outer door handle, and only one there) . I need to get the smaller plug also shown in the pics that is directly onto handle (just dig a little deeper ⛏) . I hope this helps someone in the future. Thanks everyone, great site. Let's see if this is it 🙏
https://acurazine.com/forums/second-generation-rl-2005-2012-76/08-rl-electrical-issue-fuse-953838/
Yes, so completely remove door panel shown in video in this thread, not TOO big of a pain. . Keep actuator plug (white) in but get black plug connecting directly to handle, will probably be just passenger side as said by many, was for me as well. Solved my #7 fuse issue!! 🙏
