No start?? Help please
Old Jun 27, 2020 | 01:47 AM
Bongo Vybz's Avatar
7th Gear
Just bought my first Acura‼️ A 2005 RL. Straight to the point, it’s not turning over? Bought new alternator, starter, battery. Still nothing. What’s sound I do?
Old Jun 27, 2020 | 05:25 AM
Midnight Mystery's Avatar
Null and proud of it
Look by your gear shift. You should see a small tab. Pop off the tab and push the button while simotaniosly turning the key. If it starts your neutral safety switch or range sensor has a fault.
If that doesn't work, look for the key immobilizer indicator on the dash. You key could have lost it's coding. (Usually it still cranks though)
If it still doesn't crank of start, check the starter fuse and start checking for power via test light on fuses and relays.
If that fails, check grounds.
In my RDX it was the range sensor.
Old Jun 27, 2020 | 09:17 AM
Bongo Vybz's Avatar
7th Gear
I bought a new relay still nothing .. my engine light stays on then turns off. Wassup with that ?
Question? Would a bad coil pack cause it not to turn over ?
Old Jun 27, 2020 | 09:49 AM
deepa1600's Avatar
Do you have power in Acc Or On? Check your #7 fuse in driver kick panel near dead pedal
Old Jun 27, 2020 | 11:20 AM
deepa1600's Avatar
Other thing you could try is push the gear lever forward towards the front (towards engine) and turn the key with other hand. Sometimes the shift cable wears and gets loose and and the computer thinks the car is not in park so the transmission range safety switch will cut the power to the starter. This happened in my TL sometimes.
amyz2005RL
Sep 26, 2019 09:30 AM
Rickaty
Aug 14, 2015 10:01 PM
jgro650
Dec 15, 2009 06:12 PM
stas2007
1G TL Problems & Fixes
Aug 23, 2009 04:41 AM
primetime21
Oct 25, 2005 07:40 AM
