New hid not as bright
Old Jul 27, 2012 | 07:59 PM
PortcityRL's Avatar
I had a flicker in passenger side bulb. I replaced only that bulb and now it's more yellow where my driver side is more of a clear bright light...will this bulb break in and become brighter or should I have replace both?
Old Jul 27, 2012 | 09:07 PM
TonyCD's Avatar
Yes, they break in over a period of weeks. You can expect it to become both brighter and less yellow.
Old Jul 28, 2012 | 02:11 AM
Carbon Legend's Avatar
HID Bulbs take anywhere from 10-50 hours to Color shift to a more white.
Old Jul 28, 2012 | 05:30 AM
253RL's Avatar
Didn't know that! Good info there!
Old Jul 28, 2012 | 07:44 AM
PortcityRL's Avatar
Thanks guys. I thought I read that somewhere, just wanted to be sure
Old Jul 28, 2012 | 10:11 AM
oo7spy's Avatar
OEM bulb or other?
Old Jul 28, 2012 | 12:28 PM
007 does make a good point. Most aftermarket bulbs are OK But not spot on with OEM. A lot of issues with aftermarket bulbs not seating properly in the HID projector. some have little bumps that can be uneven creating at odd HOTSPOT or can give a distorted look to the cutoff.
OEM Bulbs are Manufactured By GE, Phillips, Osram, Kioto. In our case for the RL Is GE 4200K bulbs
Old Jul 28, 2012 | 01:09 PM
PortcityRL's Avatar
It's an Oem Phillips.
Old Jul 28, 2012 | 03:38 PM
which bulb did you get the 85122 or the 85122+ ? and there might a slight difference due to the RL using GE 4200K bulbs where the phillips are a 4300K.
GE bulbs 3200 Lumens
Philips 85122 3300 Lumens
Philips 85122+ 3600 Lumens
So there is a difference in the bulbs
Old Jul 28, 2012 | 04:59 PM
TonyCD's Avatar
Nobody asked me, but...
I just got a pair of Philips D2S from Amazon. The posters who'd bought them said they corresponded to 85122+, even though their package didn't say so. I had an intermittent, slowly worsening flicker on the right side that I guessed was from the bad batch of HIDs that I'd read on this site occurred in early RL's (mine's an '06).
Anyway, I replaced the pair so there'd be no chance of a color mismatch. The 85122's are supposed to be just a bit less blue than the original 85122's, but mine show no yellow whatsoever. And if they're less blue, I don't mind, because human vision supposedly gets less visual information out of bluer light at night anyway. I'm well pleased with mine.
Old Jul 28, 2012 | 05:38 PM
if you looks at the base of the bulb it will tell you what they actually are.
From left to Right
Morimoto 4300K
Morimoto 5000k
Philips 85122+
Philips DL50
Old Jul 28, 2012 | 08:28 PM
PortcityRL's Avatar
The old bulb is an osram. I'll just order another Phillips bulb for the driverside just to be safe.
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
eastcoastguy
Sep 23, 2015 06:29 AM
