Need help with fob alarm arming.
I noticed earlier this week that while my fib works fine (lock/unkock/truck release) I'm no longer hearing the beep follwed by the doors locking. As a result, when I do lock the doors in this manner, a short time later ive returned to my car with the alarm going off (horn blaring and lights flashing. The only way I can leave my car unattented now while out is unlocked and clearly this isnt a risk I want to keep taking.
Even when I try to lock the car by pressing the door handle lock that beep (alarm engagement) isn't there anymore?
Does anyone know what happened?
Thanks in advance
Thanks in advance
The fact that it isn't beeping usually means there is something that isn't "secure" so to speak. Either a door isn't properly closed, or the hood or trunk aren't properly closed. I would start by making sure that everything is properly shut.
I was more suspecting that the coding on my Fob has somehow reset itself. My battery has been disconnected numerous times inbetween the time this started happeneing. Another thing Iv'e noticed is that my nav screen no longer auto dims at night when I turn my lights on.
Im assuming if the culprits were as simple as suggested above this issue would have been documented, although I suppose one never knows. I was really hoping to get some viable answers as opposed to needlessly driving 20+ miles away to the closest Acura dealership and having to spend the default $100 out the gate just for an observation
wait... your OP is contradicting, you said you can't arm the alarm, yet sometimes you come back and the alarm is going off? How can the alarm go off if the alarm is not armed?
How old is your battery? A weak/low battery sometimes lends itself to odd electrical malfuctions as well.
I'm hoping someone in RL land has a service manual that can give you the specs for each sensor so you can test them using a multimeter, but for the laymen's way of doing it, you can turn on the car and close the doors, try pulling on each one to see if the MID shows the door opens for a split second?
Yes, if I lock the car via the fob or handle in this present state (no beep) and then leave. I have returned a short while later to the car horn honking and lights flashing (as if someone had tried the handles or something. The first time this happened i was worried about a hit and run or theft attempt. After that i relegated it to the issue at hand.
Ive been leaving the car unlocked now as I dont want the battery to die or the alarm going off before I return. Ironically. When I have returned and disengaged the alarming, immediately after this I get the beep after the lock. Once I drive off n then get somewhere else, its the same issue. No beep on door handle lock or fob lock.
I think I may just look into a new battery. It has been on my mind as of late. Prefferably an Optima this time around. They are powerhouses.I ran one in my old legend coupe for years.
the car is contradicting itself. Lol
The fact that the screen isn't dimming when the car automatically turns on the lights makes me think battery too. I've had that exact symptom happen when I was working on the car with the radio on. The battery voltage got too low and it started killing all the peripheral equipment.
If i were in your shoes, I'd try a battery first, if not, then i'd look into diagnosing the rest of the sensors.
Does this sound like that RL door handle issue everyone has been having, project?
I'm just puzzled by the system not arming in the first place. If it's a bad battery, this would be the first ever I've read of it manifesting that way...
Hello, i have a similar issue as well, the front display keeps sending me a message that my driver side door is open. I checked numerous times to make sure the door shuts properly i see no issues. Does anyone know how to check the door sensors or where on the vehicle i can find them? I have an Acura TL 2008, many thanks.
