Need help with car not starting
Old Feb 16, 2021 | 10:52 PM
W84M's Avatar
Exclamation Need help with car not starting
So in my 2005 Acura RL, I am noticing that infrequently the car will not crank even if all the dashboard lights are on. I figured maybe it is the security system that got screwed up when I changed the battery. So I reset the system (following the advice I read) i.e., disconnect the negative terminal while key is in ON position. Then reconnect the battery terminal with key still in the ON position. The problem is still there albeit less frequent. Interesting thing is if I keep trying to crank the engine it starts after some tries.
I have linked/unlinked the fob few times without any success. The batteries in the fob are new.
I had the Autozone run a diagnostic on the car battery, starter and alternator (three times at different locations) and every time they concluded all was well. They even ran the scan tool connecting to the port in the car that found no problem.
What should I do? I am clueless. I don't know if a professional mechanic help is needed at this point. Dealership wants $149 for running a full diagnostic.
Thank you so much!
Old Feb 16, 2021 | 11:09 PM
deepa1600's Avatar
Thank you so much!
Next time it does that, try putting it in neutral and crank it and see if it starts. Or try pushing the gear lever gently towards the engine in park and then crank with other hand. If it starts then either you have loose shift cable (which will disable the starter) or a bad transmission range sensor.
Old Feb 16, 2021 | 11:52 PM
W84M's Avatar
Lightbulb
Will follow your advise when this problem occurs next time.
Thanks a bunch.
Old Feb 17, 2021 | 04:41 PM
Nomgle's Avatar
It could also just be the solenoid in the starter motor - eventually they start to stick, and you can often get the car to start by giving the starter a tap with a hammer - this isn't anything RL specific, just a general starter motor scenario...
New starter is the remedy if this turns out to be your problem
Old Feb 17, 2021 | 11:50 PM
W84M's Avatar
Thank you.
Just out of curiosity, I was told by the local Acura dealer that you can plugin a scanner to the 2005 RL and it will show the error code and pinpoint the problem source. Is that true? If so, which scanner should work? Obviously, I don't have any check engine light in the dashboard.
Old Feb 18, 2021 | 12:29 PM
TonyCD's Avatar
Thank you.
Question for you best & brightest out there: If OP's car is throwing trouble codes, would he see the envelope icon on the corner of his nav screen indicating a message awaits him with the trouble code? Or does that happen only for some codes, not all?
Old Apr 28, 2021 | 12:52 PM
HenryW's Avatar
it will show error codes in his messages.
Did you check if your ignition coil had gone bad?
supafamous
3G RDX (2019+)
Feb 23, 2021 07:43 AM
nighthawk203
Apr 18, 2016 07:16 PM
Spot
1G RDX Problems & Fixes
Mar 31, 2016 10:15 AM
JMcKenzie
Dec 6, 2014 05:38 PM
therealjmcneil
1G RL (1996-2004)
Sep 22, 2014 04:52 PM
