Moonroof
Old Oct 27, 2005 | 11:53 AM
grimie09's Avatar
Moonroof
Upon sliding moonroof switch toward rear- moonroof auto opened fully and stoped.
Sliding moonroof switch forward auto closed moonroof fully.
Pushing moonroof switch tilted up moonroof.
Now, moonroof only operates manually. Can't be sure when it is fully closed because if switch is held forward a split second past fully closed, tilt up occurs.
No combination of switch slides or pushes will restore the auto open or close.
Anyone know how to restore the auto open/close and subdue the tilting?
Old Oct 27, 2005 | 02:09 PM
vp911's Avatar
Never heard of this. I guess you could try to disconnect the battery (as this seems to solve a lot of problems - like restarting your computer).
Keep in mind, though, doing this may require you to reenter your navi and radio codes.
Otherwise go to your dealer.
Old Oct 27, 2005 | 03:52 PM
grimie09's Avatar
Thanks for the input. Scheduled for 1st service tomorow at the dealer. TSB's also to be done. I'll see what they say/do.
Hopefully I'm not going to be required to disconnect the battery to restore the auto open/close function each time I tilt up the moonroof.
I'll share the solution, if found, and also the outcome of TSB's.
Old Oct 28, 2005 | 05:22 PM
grimie09's Avatar
Moonroof mishap
Just returned from picking up RL from dealer after 1st service. It seems the moonroof problem was solved after the TSB updates. They did 05-22 Acuralink & XM control unit, 05-027 Transmission upshift & 05-028 On-Star Control Unit. Upon drive back, all seemed well after re-programming XM radio presets. Transmission shifts seem improved but I only drove 15 miles.
Old Feb 2, 2009 | 12:54 AM
AndrBryan's Avatar
5th Gear
Any one else has any more information on this? I have the same problem as stated above. I tried disconnecting the battery,didn't work.
Old Feb 2, 2009 | 09:06 AM
neuronbob's Avatar
Answer is here and you shouldn't have to disconnect the battery.
https://acurazine.com/forums/2g-rl-2005-2012-76/auto-open-close-not-working-moonroof-497993/
Old Feb 3, 2009 | 10:25 AM
AndrBryan's Avatar
5th Gear
Damn, Unbelievable my dealer was going to stick me with a bill for that. Buy that man a beer, If u ever find yourself in Atlanta hit me up, I owe you one!!!!
Old Feb 4, 2009 | 03:35 PM
socal28's Avatar
Yes, worked for me as well!
Great stuff on here.
banosser
Jul 16, 2009 07:46 PM
banosser
Jul 7, 2005 11:07 AM
jemon
Wash & Wax
May 8, 2005 09:44 PM
n1976jmk
Mar 15, 2005 08:52 PM
