malfunction SH-AWD
Old Dec 27, 2013 | 10:14 PM
Rustyboy's Avatar
malfunction SH-AWD
My 08 RL with abt 120K keeps loosing AWD whenever I take a turn at abt 35mph, this usually happens when on and off highway exit. Recently I had my alternator(OEM), aftermarket battery terminal replaced as well as aftermarket battery (interstate). Dealer claims this caused by aftermarket battery terminal. Can this really caused the issue. million thx.
I have AWD code 75 and 77 in the MID.
Old Dec 27, 2013 | 10:24 PM
TonyCD's Avatar
Do you feel your AWD going away in the car's road behavior, or are you just seeing it disappear on the dashboard display?
Old Dec 27, 2013 | 10:30 PM
Rustyboy's Avatar
when the SH-AWD light comes on, I only get front wheel drive.
Old Dec 28, 2013 | 09:08 AM
sOLLEx's Avatar
Check to make sure the fluid is full in both chambers on the rear diff. I would suggest taking it back to another dealer and having them troubleshoot the codes. Replacing the battery with an aftermarket should not have anything to do with these codes.
Old Dec 28, 2013 | 07:38 PM
oo7spy's Avatar
I'm with sOLLEx. Going around the corner is causing low fluid to "lean" and trip a sensor.
Old Dec 28, 2013 | 09:40 PM
HEAVY_RL's Avatar
I'd replace the fluids for sure. I think someone else had a sensor fail causing the same codes.
As for the terminal, it all depends. Usually a bad battery kills an alternator.
Old Dec 29, 2013 | 12:05 PM
Rustyboy's Avatar
quote by dealer:
121921 had code 75-1 acc device, 78-1 shawd unit failure 77-1 something in trans, coded 1.00 all of these codes did not come back, had new interstate battery, and aftermarket cable end on positive side of battery, weak battery could cause all these codes, if they come back i would start with cable.
Old Dec 29, 2013 | 04:12 PM
sOLLEx's Avatar
Is that what the tech wrote? An aftermarket battery cable is not going to cause just your SH-AWD to go into limp mode while going through turns. After they cleared the codes, how long was it until the codes came back? Was it while driving? If these were just history codes, they would not be disabling the AWD. Like I said previously, check your fluid level/condition. If it is good, then you will have to troubleshoot the codes that keep returning. Could be a faulty shift solenoid valve in the diff, SH-AWD control unit, or even the rear diff itself.
Old Dec 31, 2013 | 01:19 AM
Rustyboy's Avatar
The error msg came back within 30min I picked up from them. I'll take check it tmr.
thanks! keeping my fingers crossed.
Old Dec 31, 2013 | 08:17 AM
EL19's Avatar
I'm with everyone else to check fluid levels in the diff
Old Feb 25, 2025 | 07:10 PM
AJ39's Avatar
SH-AWD updates
Did you ever get the SH-AWD issue fixed..I'm having similar issues..Thanks for your response..if anyone has solved this issue- let me know what fixed it..Thanks
Old Feb 26, 2025 | 08:55 AM
TonyCD's Avatar
As mentioned above, the first thing to try is a fluid change in the rear transfer case.
Old Mar 3, 2025 | 06:42 AM
AJ39's Avatar
Had Fluids changed by dealership
Fluids changed by dealership. They're saying it's the rear differential
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
AJRozsa
Oct 5, 2015 07:50 PM
c1souk
Sep 28, 2015 11:20 AM
saturno_v
Sep 27, 2015 08:13 AM
