Light after Light after LIGHT...need help ASAP!!
Old Jun 14, 2021 | 10:49 AM
MR52WEEKS's Avatar
4th Gear
Ok...first off thanks for the admin in letting me in the forum...now the issue...
2010 RL SH-AWD TECHNOLOGY
So I have been having shifting issues from 1st to 2nd...it comes and goes...but I read where the shift solenoid gets out of specs after time...so I'm ordering those parts today..however...on my way to work I have a check transmission message, check emissions message, AFC Light, VSA lights w/triangle, engine light, check power steering message and speedometer doesn't work...
anyone have clue as to wtf is going....
THINGS DONE:
disconnected battery (everything is normal for 5 minutes the the Christmas show commences)
plan on changing tranny fluid due to the darkness
tried the hold the pedal for 30ish seconds to reset...no luck..
any info would be great...I've gotta head out the first of the month so I'm open to suggestions
and I'm in Jacksonville Florida if any other members are near by to come see.. Thanks for your time
Old Jun 14, 2021 | 06:08 PM
what is the voltage of the battery?
the car is chock full of electronics and needs full voltage, even the slightest dip in voltage will cause the electronics to go haywire
Old Jun 14, 2021 | 07:26 PM
TonyCD's Avatar
If justnspace hadn't said it, I'd have said it. He's giving you great advice here.
The RL is a generally quite reliable car, but it does have the quirk of having an electrical system that has just barely enough battery and being very, very sensitive to dipping below ideal voltage. If it does, it lets you know the way you're seeing now. That Vegas light show is no more likely to be a transmission solenoid than to be a dozen other things. Be aware that these cars can react to low voltage or a weakening battery, even if a voltage check says the battery is fine. If the voltage is low, replace the battery. If the voltage says it's fine but the battery is 3 years old, replace the battery anyway. Then see what you've got and decide what to do next.
Old Jun 15, 2021 | 04:20 AM
DanL07RL's Avatar
What they said^^^^^!!
Old Jun 16, 2021 | 02:19 PM
rlx015's Avatar
Any codes you have?
I had similar issues which are more described in this thread https://acurazine.com/forums/second-...ission-961845/ but I did get the code which pointed out what the issue is.
Note: all other lights that came on do not necessarily mean that all those are failing...
Old Jun 17, 2021 | 04:33 AM
MR52WEEKS's Avatar
4th Gear
it was an operator error...I forgot to connect the output sensor when cleaning and checking my shift solenoids
MR52WEEKS's Avatar
4th Gear
Originally Posted by rl015
Any codes you have?
THANKS FOR YOUR REPLY:
Old Jun 17, 2021 | 04:35 AM
MR52WEEKS's Avatar
4th Gear
Old Jun 17, 2021 | 07:34 AM
glad you were able to figure it out!
Old Jun 17, 2021 | 08:40 AM
rockstar143's Avatar
@MR52WEEKS try the multi quote option to quote a few people and make 1 reply.
Awesome outcome...don't you love easy fixes?
Old Jun 26, 2021 | 05:14 PM
TonyCD's Avatar
A great result—delighted to hear it. And thanks for having the class to tell us about it. Not everybody who's ever hit-and-run this board did the same.
bigbluecanuck
Jan 16, 2017 02:45 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Beezuskurk
2G CL Problems & Fixes
Jun 29, 2015 03:33 PM
Simpson975
Oct 18, 2005 10:50 PM
ncmanning7
Apr 16, 2005 04:28 AM
