Jinxed myself...door handle issue
Old Feb 7, 2013 | 01:17 PM
tla11384's Avatar
Just the other day I was scoping out the forum and said to myself that I was lucky to not have any of the door handle issues likes some of you guys on here...and boom!! today my driver side unlock sensor doesn't work. The sensor button (bubble) to lock the car works on driver door but not unlock. Passegner side works for both unlock and lock sensors. Fuse 7 is not blown but replaced just in case. My keyless access remote flashes in the MID about 30% of the time, usually goes away after I open and close the door or make a complete stop after I intially drive it. The weird thing is that it lets me start the car keylessly but then flashes that the key is missing. any solutions or troubleshoots????
Old Feb 7, 2013 | 02:58 PM
HEAVY_RL's Avatar
this doesn't sound like a door handle deal...
how old is your FOB battery?
Is the FOB near a cell phone?
did you re-sync it for good measure?
Old Feb 7, 2013 | 03:18 PM
getakey's Avatar
I agree with Heavy, does not sound like handle issue
interference from cell phone seems likely culprit as low battery in fob would get warning in MID
Old Feb 7, 2013 | 03:39 PM
tla11384's Avatar
What about the door not unlocking when I grab the handle? could be 2 different issues maybe??
Old Feb 7, 2013 | 03:42 PM
getakey's Avatar
Is fob in same pocket as cell phone?
That could cause door not to unlock.
Old Feb 7, 2013 | 03:59 PM
tla11384's Avatar
no I tried it with the key itself in hand right by the door and still nothing. walk over to the passenger side and it works perfect. No cell phone, no electronics around the fob
Old Feb 7, 2013 | 04:03 PM
getakey's Avatar
hmm - perhaps it is the handle
Old Feb 7, 2013 | 04:23 PM
oo7spy's Avatar
I know you clarified, but for the record, an electronic interference with the fob will keep you from locking/unlocking.
Old Feb 7, 2013 | 04:41 PM
HEAVY_RL's Avatar
maybe its the actuator not the handle.
Old Feb 7, 2013 | 04:45 PM
getakey's Avatar
To the OP: Does it beep when you try to unlock?
Old Feb 7, 2013 | 05:14 PM
tla11384's Avatar
no beep when grabing the handle . only when locking it is when it beeps
Old Feb 7, 2013 | 05:46 PM
getakey's Avatar
ok, doubt its the actuator
Old Feb 7, 2013 | 11:59 PM
tla11384's Avatar
Its weird that half of the sensor works and the other half doesn't I wonder if there is two different sensors and the one for the unlock is out.
Old Feb 8, 2013 | 12:16 PM
oo7spy's Avatar
There definitely are two different sensors. One is the "button" on the outside and the other runs the length of the handle on the inside. I doubt you can replace one without the other. I see a new handle in your future.
Old Feb 8, 2013 | 11:48 PM
tla11384's Avatar
good old murphys law!
Old Feb 13, 2013 | 11:49 AM
Chasillini's Avatar
tla11384 - I am having the exact same problem on my '05 RL. Added to this though are that it seems to be a bit intermittent for me. The one thing I have noticed, is that the unlock is more likely to work if the handle is wet (been raining). The lock function works perfectly. Like you, both unlock and lock work well on passenger side. I think oo7spy is right about our future.
Old Feb 13, 2013 | 01:19 PM
Mr Marco's Avatar
...random comment about keyfob battery...
Trollin' trollin' Raw Hide!
Old Feb 13, 2013 | 10:18 PM
tla11384's Avatar
guess what.? it happen to rain here in montana today and now the unlock sensor works again. the odd issue is that the lock bump is now inop for the driver side. everything still works on the passenger side....really ccontemplating in getting that aftermarket warranty.
Old Feb 14, 2013 | 08:32 AM
HEAVY_RL's Avatar
No warranty = no bitching when it fails.
Old Feb 14, 2013 | 11:13 AM
oo7spy's Avatar
There has to be something in the handle that is making a poor connection, or something on the outside is making contact that shouldn't. The operation, from what I understand, works as a capacitor. The handle holds a tiny charge, and when something touches it that is grounded, it discharges and trips the logic. Either something on the inside is not charging it every time, or there is something else touching just enough to discharge it or keep it from charging.
Debugging it would be a total bitch and it may not even be possible to fix. The part is $200. If you love the feature, you could pay, but if you are indifferent, I would pull the fuse before it gets worse and drains your battery or gives you the crazy alarm.
tman570
Jun 11, 2019 07:56 AM
divac
Aug 29, 2018 10:13 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
541TypeS
Sep 23, 2015 11:17 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
